Help Guys Running Dodge 20's
I need to know if anyone knows what the back spacing is for the 20 inch Dodge steel wheels from the 2002 - 09 Ram 1500
Re: Help Guys Running Dodge 20's
Interested, subscribing. The stock wheel is a 20x9 with a +19mm offset the black steel wheel is a 20x8. Have not confirmed its the same offset.
Also here is a handy little offset visualizer. |
![]() Join Date: Apr 2009
There were at least two guys on here running them. Cajundragger has them on an AD truck and they were modified IIRC. They other guy i can't remember his user ID was using spacers. You might look at the 73-87 forum as it has been talked about more on that forum. Also if you are running 6-lug wheels the GM transport wheels (22") have the same lug pattern and the fj cruiser wheels (17") also. Both steel.
I think sgtusmc used the Mopar wheels on one of his projects.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Just adding some other 20" steel rims that may work. 6x5.5 lugs. Need offset and center bore info.
ARMADA 09-14 20x8, steel (spare) INFINITI QX56 08-10 (20x8), steel (spare) TITAN 09-10 20x8 (LE), steel (spare) TITAN 11 20x8 (SL), steel (spare) TITAN 12-14 20x8, steel (spare) |
I don't need to know who makes 20" steel wheels but what is the back spacing on the Dodge 20x8 steel spare wheel
Call it a hijack and get over it.
