Old 08-04-2003, 09:24 PM   #1
RShaips
swapping idiot light dash for gauges,which wires need changed ?
I have put a gauge dash in my truck and I changed temp sending unit and oil pressure fitting but which wires still need to be switched ? Also I am not getting power to my ignition switch when I try to turn it over,I can jump the starter with a screwdriver but thats it. I am not getting power to the purple wire on the starter. I am putting this truck back together from a complete frame off. I know the two wires on the starter are in the correct place. If I knew HOW I could post a picture of my nice , clean , painted , partially assembled 67/71/72 2WD SWB.Thanks for the help
RShaips is offline   Reply With Quote
Old 08-04-2003, 09:31 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
click here
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 08-04-2003, 09:34 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The inst panel does not need to be hooked up to run the truck. I drove mine for a week without the panel in the truck at all. (don't ask why)
The wires that you need to chainge around can be found on GMC Paul's site, however, if you are doing a true frame off restoration, wouldn't you rather install the correct harness?
As for posting a pic, look under the box you type in when you start a thread, there is a brouse button, just click that and find the pic in your computer and if it is small enough, it'll be here.
Old 08-04-2003, 10:01 PM   #4
racedvl
racedvl's Avatar
Go here. . . . . . .
http://67-72chevytrucks.com/vboard/s...threadid=18867
racedvl is offline   Reply With Quote
Old 08-04-2003, 10:24 PM   #5
ozarkhippie
I think you have to change the headlight harness when going from lights to guages. Do you have a wire going from the pos. bat. cable to the junction block on the fender.
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
ozarkhippie is offline   Reply With Quote
Old 08-04-2003, 10:33 PM   #6
RShaips
Thanks for the GMC Pauls site,looks like I have to move a couple of wires and add a couple for the alternator. Hey Ozark Hippie got that 4 x 4 done yet ? Yes I do have the wire to the terminal by the battery hooked up.For some reason I am not getting power to the starter or ignition,I know it has nothing to do with the dash. Thanks My pic will not post says file is too big..Oh Well
Old 08-04-2003, 10:37 PM   #7
ozarkhippie
no roger I the frame is still on the trailor, I'm trying to get away to buy some sand, I'm going to go ahead and sand blast it. I think I'm going to put my &@ cheyenne on that frame for my daily driver.
Buy Sale or Trade
71 3/4 4x4
