Old 07-01-2014, 01:34 AM   #1
nzc10
nzc10's Avatar
72 c10 hard starting
My truck has been getting harder to start and sometimes stalls when in gear, idling in park or neutral its fine iv recently fitted a new edelbrock rpm proformer intake manifold and new holley 600cfm with vacuum secondries it was fine when I first fitted them now it seems to be getting worse even warm its a ***** to start the plugs look OK I'm running 8 degrees ignition timing new fuel and air filters driving it down the road it goes really well as far as I know its a standard 350 with no internal mods also has a Mallory hei. Any ideas anyone?
nzc10 is offline   Reply With Quote
Old 07-01-2014, 08:07 AM   #2
bigmac73
bigmac73's Avatar
Re: 72 c10 hard starting
make sure the choke is opening , check for vac leaks and I would try to bump up timing a little and see if that helps
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 07-19-2014, 07:53 PM   #3
nzc10
nzc10's Avatar
Smile Re: 72 c10 hard starting
Hey all just letting you know I replaced the spark plugs even though they looked OK and its make starting a lot better ,truck still stalling and a bit hesitant traced problem to low compression on number 6 cylinder then gave it a wet test no difference it was down around 60psi compared with others proberly a burnt out valve gonna whip the head off when I'm back home from work in a months time
