Old 07-01-2014, 06:24 AM   #1
JointTech
JointTech's Avatar
Motor mount direction
I got some energy suspension clamshell inserts. The clamshells have been off for awhile and I didnt think there where any alignments that matter...
I do remember that when I removed the mounts and clamshells there was only a bottom bolt on one side and it was smaller than the others. Probably because a bigger one wouldnt fit through the misaligned hole.
This is a SB350. The truck came with a 402 so I wonder after reading about differences between the mounts on BB vs SB maybe thats related.
Furthermore theres no way to get the inserts to match the directions unless you flip the clam shell around in which case none of the holes line up.
http://oi49.tinypic.com/14azj8h.jpg
This guy seemed to have a similar issue.
http://ls1tech.com/forums/conversion...t-inserts.html
Are these not stock? Any info on them? I drilled the hole out and ran a bolt through but it makes me wonder which way is up etc.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-01-2014, 04:54 PM   #2
jdw
Re: Motor mount direction
Here's a bump for you. Are those the big block framesstands? I thought the BBCaand sbc had different stands.
jdw is offline   Reply With Quote
Old 07-01-2014, 04:57 PM   #3
JointTech
JointTech's Avatar
truck was originally a BB. Had a SB when I bought it and the clamshells from what I remember seeing through the grease were attached with a small bolt on the bottom that didn't really fit on one side and no bolt on one of the bottoms.
72 C20 Long Bed
Old 07-01-2014, 04:57 PM   #4
Rude Ron
Rude Ron's Avatar
Wasn't the 72's the first C-10 year with clamshell style motor mounts?
Edited By Staff
"If I had all the money I've spent on Trucks, I'd spend it all on Trucks"
Rude Ron is offline   Reply With Quote
Old 07-01-2014, 05:04 PM   #5
JointTech
JointTech's Avatar
no idea. this is a 72 though
here where they had just a small bolt on one side and no bolt on the other.
I drilled out the holes and put a big bolt in it.
but the thing is it makes the tabs the wrong way. at least according to this pic.
The only way to get the tabs to match that pic would be to spin the clam shells 180deg. But then none of the bolt holes would line up. You can see the clam shell holes are slightly wider on one side.
72 C20 Long Bed
Old 07-01-2014, 05:14 PM   #6
JointTech
JointTech's Avatar
ok so according to this post i have big block "perches"
http://67-72chevytrucks.com/vboard/s...37&postcount=5
And the clam shells are the 72+ style.
what im not sure of is if the clam shells were used on BB and SB in 72?
72 C20 Long Bed
Old 07-01-2014, 05:19 PM   #7
jdw
I believe you need small block perches
Old 07-01-2014, 08:16 PM   #8
kwmech
The clam shells in the picture are NOT 1972. They are 73+
Old 07-01-2014, 08:33 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
I am thinking the same thing. 72 big block clamshells and perches look similar to 73+ clamshells and perches, but they are different and you cannot mix the clam and perches.
WIDESIDE72 is offline   Reply With Quote
Old 07-01-2014, 08:37 PM   #10
Lee H
Lee H's Avatar
The clam shells are a major PIA. I went with tubular mounts.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-01-2014, 09:54 PM   #11
JointTech
JointTech's Avatar
maybe why there were bolts missing when I took it apart. somebody else tired of messing with it and it did keep the engine from falling out
72 C20 Long Bed
Old 07-02-2014, 12:32 AM   #12
kwmech
You can use the clam that bolts to the block but you'll have to buy the correct mount.
Old 07-14-2014, 05:52 AM   #13
JointTech
JointTech's Avatar
im sooo close
I think a pry bar and a friend and Ill get that bolt through. Bolt is through on the other side.
72 C20 Long Bed
Old 07-14-2014, 07:51 AM   #14
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The 72 SB mounts, (at least both of mine) look like this These bolt to the motor. One 1"-7/16NC bolt the two together
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 07-14-2014, 02:57 PM   #15
JointTech
JointTech's Avatar
thanks for the pics. now if i could find some of those perches for sale Id get them. they want more than they are worth Imho as repops.
72 C20 Long Bed
Old 07-14-2014, 03:16 PM   #16
Money_pit
Money_pit's Avatar
I'm going through same battle myself. I went ahead and ordered the cpp sheet metal engine stands with the pro thane bushing they claim an 1"1/4 more clearance than the tubular stands. Waiting patiently for them to get here. Maybe another option for ya
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 07-14-2014, 03:26 PM   #17
JointTech
JointTech's Avatar
you got a link to those? Their site sucks and I don't want to pay for tubular mounts. cant find the ones you mention.
72 C20 Long Bed
Old 07-14-2014, 07:03 PM   #18
john
member #16
john's Avatar
Here are some pics of 72 and 73 up mounts. The 72's only have one hump on the top, like yours where the 73's up have two. I wonder if the clam shell plates have been mixed up with newer ones?
http://67-72chevytrucks.com/vboard/s...d.php?t=353151
john is offline   Reply With Quote
Old 07-14-2014, 08:07 PM   #19
JointTech
JointTech's Avatar
the PO was a goof... who knows what came from what.
Well a little redneck strategery and I think I got it.
I put the perches on the mounts and then lowered it all in and bolted the perches back in.
Im now thinking maybe if I had just loosened the perches I could have gotten it but this was easy enough.
Now whether this is "correct" or not I don't know but as long as the tranny goes in I think im fine.
72 C20 Long Bed
Old 07-14-2014, 08:43 PM   #20
Money_pit
Money_pit's Avatar
http://m.ebay.com/itm?itemId=281250443590
Maybe that will work for you. I agree their site just irritated me. I was actually lucky enough to find them on their eBay store
Old 07-14-2014, 08:52 PM   #21
JointTech
JointTech's Avatar
those look slick. if my tranny ends up not fitting I may pick up a set.
72 C20 Long Bed
Old 01-30-2015, 07:03 AM   #22
JointTech
JointTech's Avatar
so I just tried to put my headers on and the drivers side now hits the frame. I thought my prybaring would work but its not right. Going to pull the motor back out this weekend and do some more fiddling.
72 C20 Long Bed
Old 01-30-2015, 08:51 AM   #23
cooperhw
cooperhw's Avatar
Oh contrair Sir, you say you cannot mix the clam and perches.[/QUOTE]
Well, "Girls do it all the time". Been doing it for years.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 01-30-2015, 02:42 PM   #24
WIDESIDE72
WIDESIDE72's Avatar
Speaking from personal experience.
Old 01-31-2015, 05:18 AM   #25
JointTech
JointTech's Avatar
well i dont know what perches or clams I have but the headers are on and it fits.
whew!!
72 C20 Long Bed
