![]() Join Date: Oct 2006
L6 ignition coil question
Looking for some help here. Can some one post a picture of the wiring on the coils (+) side.
I have only one wire coming off of the starter.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Re: L6 ignition coil question
can you put up a pic of your eingine compartment so we can see just what you have
See if this helps any. Shows both HEI and points. Points will be white and pink wires to the coil
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Right on thanks !!!
63 c10 am i missing something.... WHY the yellow wire from the "R" ter. to HEI ????
I am no electrical expert by any means....just a diagram I've had on file and have used. I'd pose the question in the electrical section and see what they say. This diagram's been on the forum for awhile and was one I stuck a "sticky" on so I could access it.
it could be a major PITA if you were to lose continuity on the pink (ING.) wire as it would "RUN" while you were cranking then as soon as you got off the starter it would die
