Old 07-01-2014, 04:01 PM   #1
Dirt's72
4x4 shifter knob
Just checking to see if this is the period correct(yrs73-87) 4x4 shifter knob.
Thanks.
Dirt's72 is offline   Reply With Quote
Old 07-01-2014, 08:16 PM   #2
B_derK20
Re: 4x4 shifter knob
That looks like the knob in my '83. The '85 I had used the newer style knob and the '79 I had used the older style.
B_derK20 is offline   Reply With Quote
Old 07-01-2014, 09:26 PM   #3
Greenlee
Greenlee's Avatar
That's for NP205 I think. NP 208 has a different shift pattern.
Greenlee is offline   Reply With Quote
Old 07-01-2014, 09:50 PM   #4
Your41Plague12
Your41Plague12's Avatar
That's correct for an NP205 transfer case.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 07-02-2014, 11:26 AM   #5
Keith Seymore
Keith Seymore's Avatar
Looks correct, except it should have some texture (not smooth) I think.
K
Originally Posted by Keith Seymore View Post
I wasn't going to do anything with the shift ball....it cleaned up pretty well and was probably fine for a daily driver. But - I had a $40 credit with ClassicParts that I needed to use so I thought I would see what I could do here.
Now, you might suspect that the shift ball for this "odd ball" was probably not available, and you'd be right. However, if you were me, you'd figure that the manual transfer case shift ball was probably identical and would work in this application. So, I ordered one up:
Pretty much exactly the same! After about 30 seconds of work, you can pop the indicator out of the old knob and slip it into the new knob and VIOLA!: new shift ball!
Chevrolet Flint Assembly
1979-1986
1986 - 2019
