Old 08-04-2003, 10:07 PM   #1
1974StepSide
Play it Loud...
1974StepSide's Avatar
Help with Horn install...
I'm installing a new horn and need a little help. This is quoted directly from the instructions...
"Connect the Orange wire to any wire that has a constant positive 12 volts (not an on/off wire)."
Now as simple as this sounds, I haven't done anything like this before. Closest I've done is hooking up my stereo, but that uses "an on/off wire".
Any suggestions on which wire I could use? Obviously I don't want to go directly to the battery in case it sucks up too much juice.
Big Moe
1974 Cheyenne Super Stepside, 350/400, Hooker Headers, Flowmaster Mufflers... Needs new doors, fenders, hood, and paint.
1952 Chevy Pickup waiting to be brought back home!
1974StepSide is offline   Reply With Quote
Old 08-04-2003, 10:27 PM   #2
gldevall
gldevall's Avatar
Actually the stereo should have used a constant power for the memory.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 08-04-2003, 10:32 PM   #3
cochino12
It followed me home?
cochino12's Avatar
stereo should have used both, run it to the fuse box and put an inline fuse. Your fusebox should have an empty space with constant power.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-04-2003, 10:59 PM   #4
Russell
Professional Grade
Russell's Avatar
If not, and you have enough cable, hook it up to your cigarette lighter cord... Same with the memory wire off your stereo...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-05-2003, 12:30 AM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
In the fuse box, you will have open spaces labeled ign and bat. The ign slot is hot only when the key is on. Bat is always hot. Put a male spade connector on the wire and plug it in the bat space.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 08-05-2003, 03:40 AM   #6
Prerunner1982
Prerunner1982's Avatar
was your truck not equiped with a horn or what? what kind are you trying to install? OEM? or aftermarker air horns?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-05-2003, 11:07 AM   #7
1974StepSide
Play it Loud...
Thanks everybody for the responses, yes, it's an aftermarket horn. I still have my stock horn and all, but I just wanted to add this one.
Big Moe
Old 08-05-2003, 02:43 PM   #8
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
HOOOOOOOOOOONNNNNNNNNNNNK!
hahaha
sorry no help from me on this one!! lol
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 08-05-2003, 02:46 PM   #9
Prerunner1982
tie it into the same power supply for your original horn.... unless you are wanting them seperate.... with the aftermarket one on a switch... i just tied mine into the stock wire...
Jon
Oklahoma Roll Call
Old 08-05-2003, 02:51 PM   #10
LOHRTBT
LOHRTBT's Avatar
HoOOOOOOOOOOOONNNNNNNNNNNNNNKKKKKKK!!
hahaha..
~Dave~
Old 08-07-2003, 06:22 PM   #11
apstguy
LED King
apstguy's Avatar
Sounds like my friend who put an awooga horn in his honda. He moved it to his '92 Chevy now along with his PA system. We have WAY too much fun with that stuff...
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 08-12-2003, 01:14 AM   #12
jimfulco
I wired a 6v. VW horn into my stock horn wire. They sound reeeeally obnoxious together.
jimfulco is offline   Reply With Quote
Old 08-13-2003, 03:23 PM   #13
Prerunner1982
haha @ jim... then dont use both.. just the power wire..
Jon
Oklahoma Roll Call
