Old 07-02-2014, 08:24 AM   #1
wjjeeper
wjjeeper's Avatar
New engine is in the Bonanza
Had Ray at United Auto drop in a 99 Vortec. It's bored, stroked and balanced with GM Performance aluminum heads. Here's the update he posted yesterday on Instagram. I'm a little excited
http://instagram.com/p/p7lb07ulQ1/
http://instagram.com/p/p7jeYTuldn/
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 07-02-2014, 10:27 AM   #2
geezer#99
geezer#99's Avatar
Re: New engine is in the Bonanza
Sounds good!!
Looks awesome!!
Just in time for summer, then back to hibernation on August 3rd!!
geezer#99 is online now   Reply With Quote
Old 07-02-2014, 12:42 PM   #3
wjjeeper
wjjeeper's Avatar
Originally Posted by geezer#99 View Post
Sounds good!!
Looks awesome!!
Yeah that sounds about right. I won't get it home until July 17.... I hope to get a couple months with it on the road.
Old 07-02-2014, 02:53 PM   #4
geezer#99
geezer#99's Avatar
Just enough time to test and tune.
I mentioned Aug 3rd because when I lived in Alberta the standard joke was we had two seasons.
Summer and winter.
Summer was on Aug 2nd at noon. Rest of the year was winter.
You got any specs on that motor?
Old 07-02-2014, 09:09 PM   #5
wjjeeper
wjjeeper's Avatar
It's a 99 chevy vortec 4 bolt main 350 bored and stroked to a 396.
Fully balanced forged crank and pistons.
high volume oil pump
ARP bolts and studs
GM PERFORMANCE Parts aluminum Vortec heads with stainless steel valves
1001 fell pro head gaskets
10.9-1 compression
540 lift x energy Comp cam
Comp cam roller rockers and valve springs
intake is a polished single plane hurricane
polished billet hei distributor
polished aluminum electric water pump
Old 07-02-2014, 09:11 PM   #6
wjjeeper
wjjeeper's Avatar
Everyone likes pics
Old 07-03-2014, 12:28 AM   #7
geezer#99
geezer#99's Avatar
I guess with that motor combo you'll be running lots of initial timing. In the order of 22 to 24 degrees. Put 10 in the dizzy and add another ten with the vacuum pot.
Those electric h20 pumps aren't the best for normal running. They're more suited to quarter mile.
Any idea what your timing curve is?
I hear a tip in stumble when you wack the throittle.
Old 07-03-2014, 06:29 AM   #8
wjjeeper
wjjeeper's Avatar
Yeah the elec water pump was pulled for a mechanical one.
I don't know what timing is set at. I haven't seen the truck since May 21.
Old 07-03-2014, 06:46 AM   #9
BigBlocksRule
Please provide more info on the heads - my GMPP dealer says there's no such animal as a GM produced aluminum Vortec head. Maybe they're Fastburn?
BigBlocksRule is offline   Reply With Quote
Old 07-03-2014, 08:25 AM   #10
wjjeeper
wjjeeper's Avatar
I can get you part numbers July 17 when the truck is back in my hands.
Old 07-03-2014, 08:37 AM   #11
BigBlocksRule
Please do, that's something I'd sure be interested in using if GM really makes 'em!
Old 07-03-2014, 08:47 AM   #12
wjjeeper
wjjeeper's Avatar
This is just after it was mated to trans. Mechanical water pump and fuel pump in.
