Welding body panels
Hey guys, starting to fix some rust on my sons 72. All I have at the moment for welding wire is S.S. wire with the Tri-Mix gas. Do you think this will work fine for welding in body panels?
Re: Welding body panels
Any Ideas?
I use Argon gas and 35 wire.
![]() Join Date: Mar 2000
Stainless wire will weld it but any time an area of material is significantly different than the surrounding area it can promote corrosion. Also for bodywork you want the softest weld you can get. I don't know if stainless will give you that. Best to buy the correct wire.
Saskatoon, Saskatchewan Canada |
![]() Join Date: Dec 2012
I use 75/25 argon/co2, and .023 welding wire. Has worked the best for me on body panels.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
![]() Join Date: Jun 2012
Agree with kmc3420. Have been using this setup with ER70 wire for years. When I weld thicker material I will change over to .035 wire..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
![]() Join Date: May 2013
agree 23 or 25 for sheet metal going slow , 35 is for frames and thick stuff , allso last time I welded sheet metal it was perfect , then I grinded the welds , totally screwed it grinding , too much heat , take your time grinding also
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
No. 0.023 in mild steel wire and an Argon-Co2 mix is what you want to use.
I used to use 0.35 just because i didn't know any better. I use 0.23 and still use the 75/25 argon mix it is SOOO much better than it was. I found out the other wire one day I had a guest in the shop wanting to weld something and asked if he could change the wire and of course wanting to be a good shop host I said sure. Went and got him some small wire and then found out for myself it is the stuff for the small jobs for sure. Jim
Stainless wire is usually thick. Thick wire is no good for body work because you build too much heat just melting the wire. Also stainless wire will be a lot harder which makes grinding it more difficult as well as building more heat in the panels. .023 mild steel wire is the way to go as stated.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
![]() Join Date: May 2014
Wow, I'm glad I read this thread. I always have used 0.030 wire. Just today I bought another spool, even though I have a spool of 0.023 in my cabinet. I'm gonna swap to the 0.023 tomorrow and see how it works out
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
Just remember to turn the heat down a notch or so. The thinner wire melts at a lower temp so you don't need as much heat to actually weld your material.
#13 |
Hollister Road Co.
C25 (75/25) and .023 is better but .030 will work well. As for stainless with trimix, the issue is that the bead will have a much higher tensile strength and when it cools it will shirnk quicker and may pull the panel out of shape because its not cooling and shrinking at the same rate as the base metal.
#14 |
Awesome info, thanks guys.
#15 |
With all of this info that you guys have provided. Is there also a good thread on the best way of cutting and fitting the body panels? I was somewhat successful at installing one. But it wasn't as good as I was hoping for. A good tutorial would be helpful.
#16 |
Here is one of my favorites and has great pictures, it will get you in the right direction for sure. MP&C is a member on here as well, but not 100% on his user name on this site.
http://www.garagejournal.com/forum/s...3534&showall=1
#17 |
Here is a "Basics of Basics" I have been told is very helpful. Print it out and put it by the john read it a few times.
![]() http://www.hotrodders.com/forum/basi...els-44009.html Here is one on spot weld removal when cutting away old panels. http://www.hotrodders.com/forum/basi...ls-222549.html Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#18 |
That is good stuff. I will hopefully get better at it with practice.
#19 |
I have been using 023 wire on some body braces and such was having a hard time seeing the wire (yeah age has something to do with it).I had to weld some thicker stuff recently and put in some 035 decided to try and weld some sheet metal just turned down heat and it's working great personal preference there is no wire YOU HAVE TO USE experiment and use what makes you happy
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
#20 |
Well as much as I hate to do this, I'm going to post pictures of the panel I installed last night. Go ahead, tell me how bad of a job I did. But also tell me how to fix and make it look good, please.
#21 | |
And no, that's not me, it's some OTHER stud. ![]() But for my MIG welding, I got one of these years ago and never looked back. I can't stand the auto dark, this thing has really worked well for me. And forget all the weird stuff about forgetting and your chin hurting using it to open and close the lense and what ever, unless you have a medical condition where you have a problem with your chin this thing works GREAT and it is second nature you don't even think about it just minutes into using it. It has a very large lense so you can really see what you are doing. http://www.accustrike.com/ ![]() Brian
#22 | |
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=634624 Brian
#23 |
It looks like your doing just fine. Welds are spaced out. Panel doesn't look warped. You cleaned down to bare metal. Just take your time and slowly fill the gaps with more tack welds. Let things cool down in between. Once you think your done welding the gaps closed then slowly start grinding and finishing the welds.
#24 |
#25 | |
