Old 08-04-2003, 10:58 PM   #1
71Seth
71Seth's Avatar
Question new to 4x4's....How do you get into 4lo w/o grinding gears
As i said i'm new to the 4x4 world. I have a 97 full size chevy 4x4. I have no problem going into 4hi, but 4lo grinds when i am tring to get into it. I have been shutting the truck off and grabbing 4lo. what is the correct way to select 4lo quietly and smoothly. Any help will be great. Seth
97 ext cab 4x4
04 pontiac grand am
05 honda rancher AT (yellow)
71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter
71Seth is offline   Reply With Quote
Old 08-04-2003, 11:34 PM   #2
'89Z71
'89Z71's Avatar
I hope that you are not trying to shift into 4wheel drive on the go, especially into 4 low Always come to a stop and put in neutral(on the column or push in the clutch for manual) and then select 4hi or 4low. If you're still having problems then my best guess is that somethings wrong with your 4wheel drive. Hope this helps.
'89 GMC Sierra Z71 -"Scream'n Demon"
*** LOUD PIPES SAVE LIVES ***
My Truck
'89Z71 is offline   Reply With Quote
Old 08-05-2003, 09:26 AM   #3
alf4444
alf4444's Avatar
Its okay to shift into 4hi while moving in your truck just not 4lo come to a stop and it should go in fine.
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 08-05-2003, 10:55 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
If I remember correctly, on my 95 Yukon you are supposed to be going like 2 or 3 mph and put tranny in nuetral than shift to 4 Low.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-05-2003, 07:31 PM   #5
71Seth
71Seth's Avatar
thanks guys, no i'm not shifting into 4lo on the move. I have in problem with 4hi. OK with truck idling in neutral and tranfer in 2hi, if i shift the transfer into neutral then try and go into 4lo or 2hi i get a very loud grind. Like putting a auto trans in park while moving but louder. If I shut the truck off then select the range i have no problems. Maybe this will help
thanks Seth
97 ext cab 4x4
04 pontiac grand am
Old 08-05-2003, 07:44 PM   #6
Kman
some times if you stop and shift into reverse and apply slight preasure to shifter it will slip right in when gears line up if not shift back to neutral then drive its worked for me
Kman
New 89 chevy 1500 driver
72K20 rust bucket project stripped down to the frame engine rebuild started
71 Blazer - another procect
Kman is offline   Reply With Quote
Old 08-06-2003, 12:48 PM   #7
mnick
You need to put your truck in park or push the clutch in and
wait for the internals of your trans to stop turning. Then you
can put it in 4 low. The transfer case isn't syncronized like a transmission.
mnick is offline   Reply With Quote
Old 08-18-2003, 11:28 PM   #8
71Seth
71Seth's Avatar
thanks guys, just have to give it a bit to let the gears stop
97 ext cab 4x4
04 pontiac grand am
Old 09-04-2003, 11:57 PM   #9
72k5
72k5's Avatar
My auto trans 4x4s do it too. The trick is to do exactly what you are already doing, just don't pause in transfer case neutral. The automatic will start to spin even in transmission neutral with no load on it (ie when you put the transfer case into neutral) then the spinning transfer case input gears will grind when you try to re-engage them.
If I stop in neutral, the only way I can get the transfer case back into gear without grinding is to shut the engine off first.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements.
72k5 is offline   Reply With Quote
Old 09-05-2003, 08:18 PM   #10
vycc
vycc's Avatar
have you checked the oil in the transfer case????
1981 GMC Sierra 1/2 Ton SWB 4X4
vycc is offline   Reply With Quote
Old 09-07-2003, 11:13 AM   #11
71Seth
71Seth's Avatar
I have had no problems now that i am putting the truck in park, giving it a sec to stop, then slamming into gear. Thanks for the help. Yes all fluids are full.
97 ext cab 4x4
04 pontiac grand am
Old 09-08-2003, 03:24 PM   #12
vycc
vycc's Avatar
glad to see all's well now, man
Old 09-08-2003, 10:23 PM   #13
71Seth
71Seth's Avatar
tnkx
97 ext cab 4x4
04 pontiac grand am
