Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-02-2014, 06:41 PM   #1
1972K20
1972K20's Avatar
Tire and wheel ID help
Do these have tubes? Do I need to change wheels if I go with a tubeless tire? I believe these are "split rims."
1972K20 is offline   Reply With Quote
Old 07-02-2014, 07:50 PM   #2
jumpsoffrock
Re: Tire and wheel ID help
Yes they use tubes and you would need different wheels to go tubeless. They are not always easy to find.
jumpsoffrock is offline   Reply With Quote
Old 07-02-2014, 08:53 PM   #3
1972K20
1972K20's Avatar
Thanks, are you saying it's hard to find that lug pattern?
Old 07-03-2014, 02:08 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Later light c-60's think u haul had tubeless 19.5's in that pattern.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 07-03-2014, 04:35 PM   #5
1972K20
1972K20's Avatar
Thanks, would a wheel like this fit?
http://www.ebay.com/itm/1-wheel-C65-...561783&vxp=mtr
Old 07-05-2014, 02:14 AM   #6
jumpsoffrock
You need to measure your bolt pattern, and also the hub diameter. Best way to confirm if they will fit your truck.
Old 08-08-2014, 03:16 PM   #7
tecky11
i have s similar patter. newere truck tho. 1995 c3500HD(cab and chassis axles) uses a 10 x7.25 circle, i can measuer the ctr bore for you if you need me to
Truck: 1972 International Harvester 1210
Engine: Caterpiller 3116 220 HP 630 tq
Transmission: Eaton Fuller rt 6610
Axles: Merritor I beam front axle
tecky11 is offline   Reply With Quote
