Old 07-02-2014, 09:23 PM   #1
davepl
davepl's Avatar
Big block fan shroud notch
My truck has a notch in the fan shroud on the driver's side where the upper rad hose crosses it. I cannot tell if this was original or if the original owner cut it for clearance.
With the NAPA replacement hose it indeed would need the notch if you're not careful. I managed to slide the rad end out on the spout and cut some length off at the thermostat so I have an inch clearance and don't need the notch.
So, did they have a notch from the factory?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-02-2014, 11:35 PM   #2
Turbo1dr
Turbo1dr's Avatar
Re: Big block fan shroud notch
Mine doesn't appear to be notched. The hose doesn't even come near it.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline   Reply With Quote
