![]() Join Date: Sep 2013
Fuel gauge--pink wire
I'm replacing all the gauges in my 64 C10 with after market gauges. The wiring for the original fuel gauge consists of a tan and pink wire. I know the tan wire goes to the fuse box and eventually to the fuel sending unit. The new fuel gauge (Equus) requires three wires; 12 volt power, ground and sending unit. I know the tan wire goes to the sending unit terminal, but is the pink wire from the factory plug a 12 volt power or a ground? The truck is in a full restoration so I don't have any underhood wiring to hook up the battery to test if the pink wire is power......tx
Re: Fuel gauge--pink wire
Your 60-66 FAQ Index...
Electrical Threads several threads there with wiring diagrams. 60-66 Trucks, links: hilandr451 site / has wiring diagrams -- faq truck tech / 60-66 section more wiring information. -- go explore. -W |
A simpler answer - Yes the Pink wire supplies 12V power to the gauge with the key "on".
I'd recommend getting your hands on a wiring diagram for when you start final assembly. |
I just down-loaded a color copy of the wiring diagram this morning; very helpful............THANKS
| Bookmarks |
