07-03-2014, 12:37 PM | #1 |
55.5 VIN location (in cab)
Hi
I have been searching, but am either getting conflicting info, or I'm not bright enough to decipher the info I'm getting (probably the latter). I'd like to know where the VIN plate should be located in the door jamb of a 55 2nd series. Is it either of the pictures here? |
07-03-2014, 01:02 PM | #2 |
Re: 55.5 VIN location (in cab)
Turquoise truck is location for 55.5-57 other is 58-59. Vin is also stamped on the top drivers side frame rail just in front of the steering box and top drivers side frame under the step. First is easy to see if it hasn't been ground off or filled. The one under the cab can be a challenge but usually you can get an impression using chalk and a mirror or paper and pencil rub. It was the "secret" one used to find stolen trucks that had the other defaced and removed. The one on the jamb is help on with special rivets so you can tell if its been removed or changed.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-03-2014, 01:31 PM | #3 | |
07-03-2014, 02:36 PM | #4 |
My 57 was welded on and so was the one on the 56 big window I replaced it with.
Kim |
07-03-2014, 05:20 PM | #5 |
I could be wrong....
07-03-2014, 05:44 PM | #6 |
On my 55 2nd series the vin plate is spot welded on the door pillar.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
07-03-2014, 10:08 PM | #7 |
A320 Pilot/USAF Retired
My cab is a 58 and its spot welded on.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
07-04-2014, 02:31 PM | #8 |
I looked in the FAM and it clearly states "spotweld 2 places" so I stand corrected for 55-57. I do not have the 58-59 supplement so cannot check that. I looked at mine and it is spot welded too, I was sure it had the funny rivets. May have been confusing it with the 64 chevelle vin...
07-05-2014, 02:40 PM | #9 |
Thank you everyone! I appreciate all the assistance (as always).
