Old 07-03-2014, 01:42 PM   #1
frankyjoet
Red face tapping noise valve area
Have 73 GMC 350V 3/4 TON 5.7L rv cam roller rockers. this engine is not broken in. has 50w oil. tried adjusting valves get a tweety sound with the tapping noise. i am trying to do the adjusting with the valve cover off at low idle on the pass side. recently replaced all plugs and header gaskets. the truck sits in the garage and gets started daily. prepping for paint. need help
frankyjoet is offline   Reply With Quote
Old 07-03-2014, 01:46 PM   #2
mud.man.rj
mud.man.rj's Avatar
Re: tapping noise valve area
Not sure on noise but found with all the roller rockers I have used that they actually make more valve train noise that a stock rocker arm, is there 1 certain rocker arm or all of them. If you adjust with running at idle, loosen till it clicks then take click out and tighten 5/8 of a turn past that and should all be good if not maybe wiped a lobe out if it is really loud.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 07-03-2014, 02:10 PM   #3
bnoon
Why in the world are you using 50w oil on a new engine??? You should be using thinner oil if anything, plus a break in oil (or additive) with high zinc content. The heavy weight oil alone could cause issues because the oil can't get to where it needs to go. New or recently rebuilt engines can have very tight tolerances which restrict oil delivery. You're adding to that restriction by using a heavy thick oil.
For any hydraulic lifter, adjust to zero lash (no up and down wiggle movement), then add half to three quarters of a turn. I've never needed to do a hot/cold adjustment ever on hydraulic lifters. I have heard of (but never experienced) bad hydraulic lifters out of the box. If that's suspected, check that the spring lifts back up after pressing it down with the pushrod firmly. Should be a 16th to an 1/8th inch of travel max. If there's no spring return to the "up" position = bad lifter. This travel is what takes up the slack caused by expansion/contraction during running/sitting cycles. It's also what gets rid of complicated adjustment procedures of mechanical lifter setups that you don't need to do here. Now, if you have mechanical lifters on an RV cam, then we have other things to talk about.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 07-04-2014, 08:28 AM   #4
naphtali5725
naphtali5725's Avatar
if it's a hydraulic flat tappet cam... if you don't follow proper cam break in procedures with a good break in oil, or a high zinc oil, preferably 10-30/10-40 it will wipe a cam lobe in no time...
how many rockers are making noise?
check this
http://www.cranecams.com/uploads/breakin/548e.pdf
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 07-04-2014, 02:55 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
I agree with bnoon. Change that oil back to 10-30 with a zinc additive. Also, as far as I'm concerned, if the roller rockers are not made by Crower, they are garbage.
Old 07-04-2014, 07:28 PM   #6
frankyjoet
bnoon and others, problem resolved. found tdc cycl 6 adjusted rocker no noise. thanks for the help.
Old 07-04-2014, 09:46 PM   #7
bnoon
Had the same problem on Mr. Green Jeans a couple of times. Had a bad set screw on one of my poly locks. Good luck with it from here.
