Old 08-04-2003, 11:25 PM   #1
Pardue'sCustoms
Pardue'sCustoms's Avatar
What would you do
ok i just lower my truck with spindles and spring in front and flip kit out back .
Now my front to me sits a little higher then the back
i put 3 " drop spindles on it and 2" lowering coils on front and flip kit out back either i can buy 2.5 lower coils or just saw a around off of these what other ideas do ya thank of i know i need to bag it
Pardue'sCustoms is offline   Reply With Quote
Old 08-04-2003, 11:56 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
First off, make sure the springs are seated properly in the spring pocket. That can make a difference. If that is not a problem, I would pull the springs and cut half of a coil off. Any thing less is hardly worth the hassle. I would not take a full coil of on the first cut....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-05-2003, 12:01 AM   #3
Russell
Professional Grade
Russell's Avatar
I think that it looks awesome like that... Its a very solid stance...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-05-2003, 12:09 AM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
Did you use shackles with the flip kit? If so, which hole did you use? If you used the upper hole, change it to the lower hole. This will give you around 1" of lift out back.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 08-05-2003, 06:54 AM   #5
Pardue'sCustoms
no shackles was used iam sure they are seated but i will check today
Old 08-05-2003, 06:54 AM   #6
bigblock73
yeller
bigblock73's Avatar
Does your truck have the HD leafs out back (eight leafs I think)? If it does, that could explain this. Most trucks have the 4 leafers and when you flip yours compared to theirs you will actually get more drop due to the thickness of the leafs. Just a thought and a possible answer to what is happening with your truck.
...Jeff
bigblock73 is offline   Reply With Quote
Old 08-05-2003, 09:11 AM   #7
Lowerd1
Full Time Loser!
Yea its does seem to sit higher in the front from the pic.
I would definatly find a way to make it sit even or at the least the front sit lower.
How long ago did you do the lowering? The front may have just not settled and that may explain it also.
1979 C10 - Its being rebuilt.
1978 Silverado - Its being driven.
1995 Grand Prix GTP - Its stock
Lowerd1 is offline   Reply With Quote
Old 08-05-2003, 02:35 PM   #8
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
the front wont settle that much
i would say the springs arent seated right. how much was your kit supposed to drop it in the back anyways??
~1980 c10 chevy scottsdale~
~2.5/4 drop 305/th350c~
c10scotty is offline   Reply With Quote
Old 08-05-2003, 02:50 PM   #9
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
personally I am surprised that no one else has said this. I seriously doubt the truck is sitting higher in the front...but the front fenders are cut higher up on the body than the rears. So it appears that it is sitting higher in the front. My truck is the same way. its not really higher it just looks that way.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 08-05-2003, 06:11 PM   #10
Pardue'sCustoms
4 leafs out back and i am pretty sure ther sitted and i agree with lobirt the creas down the side is level it is 3" spindles and 2 ' springs 5 front and flip kit out back
