Old 08-04-2003, 11:28 PM   #1
hobby67stepside
home made gas tank
Here's a pic of my gas tank. I had a shop make the breaks, but I welded it together. Had a few pin hole leaks, but zapped them and it held the same aire pressure for about five days so I think it will work. I didn't weld the fill spout in at this point cause it was easier to get a real good pressure test without it. I have since welded it in and installed sender unit.
  • '05 2500 HD Silverado 6.0 liter
    '97 2500 4X4 454 eng
    '92 2500 4X4 350 eng
    '78 K20 4X4 400 eng
    '70 Boss 302 (owner for 27 years)
    '57 Ford shortbox 383 stroker TH350 tranny
    '23 T-bucket (built in '78)
    '02 Explorer
    '67 C-10 short step
NW Iowa
hobby67stepside is offline   Reply With Quote
Old 08-04-2003, 11:30 PM   #2
hobby67stepside
Another view:
    '78 K20 4X4 400 eng
    '02 Explorer
    '67 C-10 short step
NW Iowa
Old 08-04-2003, 11:33 PM   #3
69mychevy
yes i did post something
goin underneath your bed? i wish i had space behind my seat!
you can want in one hand and s h i t in the other and see which fills first
NO MATTER HOW BEAUTIFUL THE GIRL(S) IN MY AVATAR IS PLEASE READ MY POST
69mychevy is offline   Reply With Quote
Old 08-04-2003, 11:45 PM   #4
hobby67stepside
Yes, I made it to fit and fill the whole area between the frame rails on a short bed (at the rear of course). If I have calculated correctly it will hold about 26.8 gal.
    '78 K20 4X4 400 eng
    '02 Explorer
    '67 C-10 short step
NW Iowa
Old 08-05-2003, 12:45 AM   #5
71sub
71sub's Avatar
deminsions
Do you have a "blueprint" of what you did ?
It looks awesome and holds the amount of gas I need for mine !
Ev
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 08-05-2003, 12:50 AM   #6
hobby67stepside
71sub, no I just took measurements between frame rails and fore and aft and with some planning took those to the "iron works" with what I wanted. They did a fairly good job but I had to take the lower piece with the upswing to another shop (closer to home) for some tweaking. Any good iron shop can help you alot. Oh, by the way I've got about $75 in this in shop work and iron. And its heavy guage. I don't know the guage but the thickness of the material is right at .10" That's not too far from 1/8" and that is thick for a gas tank!
    '78 K20 4X4 400 eng
    '02 Explorer
    '67 C-10 short step
NW Iowa
