Old 07-03-2014, 10:28 PM   #1
RANDY COX
RANDY COX's Avatar
3 spd floor shifter
question for you guys, my uncle has a 54 with 3 0TT and was wondering does anybody make a good aftermarket 3 spd floor shifter, He's needing more gut room and needs to do this conversion in order to shorten the steering shaft and move the column closer to the dash to help with the gut, removing the gut is not an option as he's worked very hard to get.... Thanks.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 07-04-2014, 12:20 AM   #2
OrrieG
OrrieG's Avatar
Re: 3 spd floor shifter
A LONG time ago, I used Hurst products. Do not know about the column, it is enclosed, shortening will require resplineing it unless you want to risk cutting and welding, which I never recommend on steering parts.
OrrieG is offline   Reply With Quote
Old 07-04-2014, 06:26 AM   #3
RANDY COX
RANDY COX's Avatar
Thanks it would be a cut and weld and sleeved over then bolted..
1964 BBC 402 4x4
Old 07-04-2014, 08:35 AM   #4
geezer#99
geezer#99's Avatar
Here's what you need. Best you can get. Has a bolt on stick so you can install different height or shaped sticks. You need the install kit too.
I've used them for the same reason. Took me years to develop my 'Dunlop" too!!
http://www.summitracing.com/int/part...commendedparts
geezer#99 is online now   Reply With Quote
Old 07-04-2014, 08:55 AM   #5
1project2many
Hurst used to make a pickup shifter with a longer handle.
http://www.summitracing.com/parts/huu-5010016
1project2many is offline   Reply With Quote
Old 07-04-2014, 09:52 AM   #6
RANDY COX
RANDY COX's Avatar
Thanks guys...
1964 BBC 402 4x4
