Old 07-04-2014, 12:12 PM   #1
'65 chevy lover
Another Transmission question
I have another probably stupid question to ask. I'm changing over from an automatic coulmn shift to a floor shift. Question is, how do you know where to cut the hole for the shifter? Planning on using a lokar trans mounted shifter on a TH350 trans. Truck is '65 long bed. It does not have a removable hump.
Thanks for any help.
'65 Chevy Lover
'65 chevy lover is offline   Reply With Quote
Old 07-04-2014, 02:54 PM   #2
earl84
Re: Another Transmission question
I've never done that before, but I would just get as much put together as possible, then run a drill bit up from the bottom in the area where the shifter needs to penetrate and start cutting a small amount out until you have the hole in the correct place and the correct size.
earl84 is offline   Reply With Quote
Old 07-04-2014, 05:37 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The beauty of the Lokar is that it allows so much fore and aft adjustment. I've only put one in my own vehicles, but I chose the location from above so I could assure it didn't hit the dash or seat when operated through the range. Then using landmarks on the floorboard I went underneath and made sure it fell within range over the top the the trans. There's enough sets of holes to choose from on the Lokar that there's a lot of leeway as to positioning.
Old 07-04-2014, 10:44 PM   #4
'65 chevy lover
Thanks to all for the replys.
