Does the side the alternator on matter?
Hey, I working on a rebuild on a '72. It's actually a Blazer but I figured more eye here. It has a 350 small block and I'm building a small block stroker for it. My question is on Alternator position. You can buy mounts for either the Drivers (lh) or Passenger (rh) side and even get a wire harness for either side. Truck does not have Air conditioning and it doesn't have to look stock to me. Is one side better than the other for one reason or another.Sorry if this is a dumb question but I thought I may as well ask before I commit one way or the other.
thanks for any help.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
![]() Join Date: Mar 2003
Re: Does the side the alternator on matter?
It is still going to charge the battery either side it is on. The question is what water pump are you going to run will determine placement of the alt
![]() Join Date: Mar 2014
mine hangs to the left.....
also power steering you dont want to overload one side of the engine so if power steering on bottom driver side then if no a/c the smart choice is alt top pass side
every ounce counts in balance of engine
