![]() Join Date: May 2009
Fleetside tail light bezels
I had asked this question quite some time ago, and received varied answer's but they were not helpful so I thought I would try again. Does anyone in the aftermarket make a bezel of SS instead of the tinfoil or aluminum one's found on the vehicle? These dent and scratch so easy that in awhile they look crappy. I slipped with a screwdriver installing the taillight screw and put a big dent in them without much force at all, they look much better without them IMO so what does anyone else think about the aluminum bezels?...Vernski
![]() Join Date: Feb 2011
Re: Fleetside tail light bezels
I have never seen stainless re-pops used for 64-66 trim. All of the trim and moldings made of aluminum for these trucks are very fragile and not worth the time to repair correctly and re-pops are thinner yet. Use extreme caution when handling.
I'm sure this has been thought of before but here goes.
A friend of mine makes aluminum license plate frames for Harleys with his CNC machine then gets them chrome plated. As with every thing else the first one would take a bit to program but after that you sit back and let the machine do it's thing. Not sure how much of a market there is for this but you would end up with a solid piece of chrome. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes they could be CNC machined from billet aluminum, but they would be a bit spendy.
| Bookmarks |
