Old 07-05-2014, 11:45 AM   #1
72tutone
Need some measurement help
I just bought a set of 20x8.5 and 20x10 boss 338 wheels. As my truck sits right now its on jack stands. Is there an easy way to determine the size tires I want/need?
I would like to run 255/40 and 295/40 however I see some folks running the same setup 4/6 ECE drop kit and they can run a 245 and a 275 in the rear.
Is there a good way for me to determine what I can run?
72tutone is offline   Reply With Quote
Old 07-05-2014, 12:00 PM   #2
Ends
Re: Need some measurement help
You can tuck just about any size rim and tire, The height is not the issue you need to figure out its your back spacing to see if you will clear the fender wells.
LAYDIIREST member
1970 C10 stepside full tube Chassis, supercharged 454 and much more, 95 motor and trans swap, pro street SLAMMED!
1951 Fleetline custom chopped, channeled, narrowed.
Ends is offline   Reply With Quote
Old 07-05-2014, 01:03 PM   #3
john
member #16
john's Avatar
check this out. It should answer your questions.
http://www.google.com/custom?domains...D%3A1%3B&hl=en
john is offline   Reply With Quote
