Old 08-05-2003, 01:33 AM   #1
Warrens69GMC
Warrens69GMC's Avatar
lifted spindles
We plan on using the front brakes from a 77 c-10 on the front of our 69 gmc. Does anyone know of a manufacter of 3" lifted spindles?
Our goal is 3" front lift, 2.5" rear 31x10.5x15" rims, 5 lug all around and more than likely a tbi 305 w700r4.
Any help appreiciated.
warrens69gmc
Old 08-06-2003, 10:12 AM   #2
slam33
slam33's Avatar
I've been looking but no one is doing them. The best you can do is an upper a-arm that will get you the 3" but you will be using 73 and up bushing setup. AIM has them.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 08-06-2003, 10:27 AM   #3
Warrens69GMC
Thank you!
Thanks for lookin', I saw them about 2years ago but havent seen them lately. Cant remember who makes them.
warrens69gmc
Old 08-08-2003, 10:10 AM   #4
1FaastC10
1FaastC10's Avatar
i'd body lift it before i spent anything on parts from AIM. they're junk!
1FaastC10 is offline   Reply With Quote
Old 08-08-2003, 02:53 PM   #5
stepn67
Junior Member
stepn67's Avatar
I've been told (but have not checked it out yet) that if you get a lower control arm from a 3/4 ton C20 you can then use a 3" lifted spindle from an 88-98 1/2 ton chevy, which will also give you a 6 lug disk up front. I've never bought from AIM but heres the link to the spindles.http://www.truckn-store.com/product....t.asp&ID=22748
stepn67 is offline   Reply With Quote
Old 08-08-2003, 06:31 PM   #6
stepn67
Junior Member
stepn67's Avatar
Whoops - Just read my reply and need to clarify it a bit. The lower "A" arm should be from a 67-72 3/4 ton truck. Thats becuase the lower ball joint on the 88-98 1/2 ton is the same as the 67-72 3/4 ton.
Old 08-19-2003, 10:31 PM   #7
pa_snowman
Hey stepn67 you mentioned 6 lug disk brakes?!?!?!? What year is a good swap to put in a 67 1/2 ton? I want to upgrade when I rebuild my truck. (I got it in tucson about 10 yrs ago)
warren, if you put 3/4 ton coil springs in you will easily have the clearance for 31-1050 tires, and it will lift your truck about 2 inches. i have a heavy-half ton and when i broke a front spring they were the closes thing i could find but after i replaced the front springs i had to replace the rear also because the front was noe higher then the back.
jim gallagher
pa_snowman is offline   Reply With Quote
Old 08-19-2003, 10:55 PM   #8
slam33
slam33's Avatar
Are you sure you didn't use BB springs. I just did a new set of 3/4 ton spring in my 1/2 and got no lift out of it. The BB springs will get you almost 2"
</A>
Old 08-19-2003, 11:15 PM   #9
pa_snowman
As far as I know they were 3/4 ton, this was 8 yrs ago though. Before the spring replacement when parked next to my friends 69 1/2 ton, both with 31 tires, mine sat 2 inches lower than his. that was level not leaning or sagging. Maybe it had something with mine being what was called a "heavy-half" ton CST (custom sport truck) and his was a plain jane.
jim gallagher
Old 08-20-2003, 02:02 AM   #10
Warrens69GMC
lifted in tucson
My buddy lifted his c10 using 1ton spring all around. He is trying to get me to do the same-only mine has rear leafs. I was thinking that would be an easy way-I have to make things harder than they have to be-lol ''.
I need to find 1 ton (52")leafs for the GMC. I needs new leafs anyway. That waould get me 2 inches up front.1 1/2" rear and a 2-3" body lift is what would be perfect.
warrens69GMC
