Old 07-05-2014, 03:38 PM   #1
bdiamond
Column to floor shift conversion
I'm working on an 82 2wd blazer. It currently has a 700r4 that got filled up with water from a bad radiator. I am kicking around the idea of swapping it over to a standard transmission like a super T-10. I have sourced a floor shift tilt column and hydraulic clutch assembly. I expect to have to build/modify the crossmember, but what else is different? Will my main underdash harness work? I can think of the neutral safety switch and backup light switch being different. Are these connectors separate from the main harness or should I swap all the dash harness? I searched on here a little but didn't come up with too many answers.
bdiamond is offline   Reply With Quote
Old 07-05-2014, 03:54 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Column to floor shift conversion
I wouldn't switch the harness for the simple changes you need to make. Reverse lights and neutral safety go through the column switch. Unplug it and wire from it as necessary.
Just call me Sean is offline   Reply With Quote
