1969 with 2000 seat no mod needed
mounted these seats in no time at all sat the middle in first drilled holes then sat driver in bolted to middle then drilled outside holes no brackets or anything dont know if anyone knew that 2000 silverodo 3 door seats were direct fit or not so i thought i would share
now got to steam clean them |
Re: 1969 with 2000 seat no mod needed
does this color combo work red int black accents charcoal seats
just sat the door panel there for the look good bad wtf was i think let me know thanks |
also grill with or without emblems ??? dont know what to do
My vote is without emblems.
I wanted to run those in mine but the backs are too thick for us bigger framed guys they really push you into the steering wheel
Not sure if you reinforced the boots or not but most recommend since the seat belts are bout into the seat. There is some aftermarket add ons that help with this but I don't recall what they are called |
#8 | |
Didn't think that would give you anymore room once the seats usually hit the cab above the tank below the window anyway.
Hope it works for you |
ya it worked mind you i have to sit alittle more up right then i want but im lower then with the factory seat and the old gut doesnt hit the wheel lol it is alot more roomy then i thought
#11 | |
Some also don't care for the height of new seats vs a factory bench or bucket seat set-up from 67-72. They are comfortable seats though.
#12 | |
#13 |
That being said, if you drilled holes for the install, make sure the hardware used to secure the seats to the floor are the proper grade & reinforced since the seat-belts are tied to the seat frame/s.
#14 |
oh for sure i plan to use steel plate across from one bolt hole to the other i have kids im a safety first kinda guy i will take pic's of the job when its done
#15 |
later today i will take a pic of me sitting in it
#16 |
plus the combo of having a mid 80's column and smaller wheel with the lower seat works like i said im a tad over 200 lbs and 6'2" tall worked out great , with the old stuff i sat way too high im a little tall in the body so my head almost touched the roof with factory seat
