07-05-2014, 08:21 PM | #1 |
60-63 repair panel above w/s same as 64-66
hello all
ihave been working on some rust repair above w/s on my 60 I cut off a donor roof from a 65 a few years back from a pick n pull. and just recently bought the repair panel for a 60-63 that LMC and other parts suppliers sell.after cutting off the roof skin from the donor that I will be using on my 60, the above w/s section was in very good shape from the 65 donor so I carefully removed it and compared it to the lmc 60-63 panel. they looked identical to me, the bends around the w/s opening are a bit sharper than the repop. and it fits better where it meets the A pillar,so I will be using the original 65 panel on my 60. if you guys with a 64-66 need this repair panel then buy the 60-63 section I don't know why they list it only as for 60-63? here are a few pics I had one showing the the fit at the A pillar with the repop but it got lost. |
07-06-2014, 09:32 AM | #2 |
Re: 60-63 repair panel above w/s same as 64-66
I think they list it that way so it doesn't confuse people because of the different cabs. The GM part number 3833985 shows it fits 1960-1966 .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
07-09-2014, 11:35 PM | #3 |
1961 crewcab
I always thought that that was the same piece, from the visual comparisons I had done, and 60-66's post and yours cement the deal.
seems like it would be smart to sell the same piece to the 64-66 people too!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
