07-05-2014, 10:52 PM | #1 |
where does this go
just saw this on another thread im putting my truck together and i have the piece on the left no idea what it is or where it goes please help
07-05-2014, 10:55 PM | #2 |
VA72C10
Re: where does this go
thats the center support that goes under the hood latch and attaches to the grill
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 07-05-2014 at 11:07 PM. |
07-05-2014, 10:59 PM | #3 |
the two right pieces are what is riveted to the aluminuim grill band also
07-05-2014, 11:19 PM | #4 |
lol i get it now i didnt take the two pieces off my grill but i guess i took the center out 2 yrs ago just forgot what it was for thanks do i have to use it my grill is modified dont know if it will fit now
07-05-2014, 11:36 PM | #5 |
usally when you get a junkyard or used grill they are there , if you get a new grill , you will have to mount the mounting flanges on the band/grill
07-06-2014, 12:00 AM | #6 |
i have the side pieces on but when i made my grill insert i did not know about the center piece now my grill is done can i get away without using the center piece
07-06-2014, 12:02 AM | #7 |
i dont think i need it |
07-06-2014, 12:12 AM | #8 |
The center support keeps the grill from warping over time from the stress of the hood pushing down and pulling up on the center of the grill as wind catches it, if you aren't going to put the center support back in at the very least you need to fabricate a long backing plate and bolt it in under the top rail of the grill to give it some strength so it doesn't warp the grill over time.
07-06-2014, 12:30 AM | #9 |
i will find a way to make it fit dont wanna mess up all my hard work i think i can still find a way to make it bolt up thanks guys
07-06-2014, 12:32 AM | #10 |
The other idea is if you don't want to go through all the hassle and expense of fabricating a backing plate out of aluminum you can just bolt the center support back in.
07-06-2014, 12:40 AM | #11 |
ya i will have to trim a little mesh but i think it will go back in lol just wish i knew what it was long time ago i have been moving that piece around my garage for months not knowing what it was for should have asked when i came across it live and learn
