Old 07-06-2014, 10:38 AM   #1
woody82
Could it be a posi.?
I bought a 72 Cheyenne long bed factory big block recently.I have been doing some work to it.I would like to post some pictures of it when I feel it is ready.My question is could it have a posi rearend under it?I was changing the tire on the right rear and noticed it would not turn.I didn't jack up the other side because it was to darn hot that day.
I will post some pictures at a later date and tell you all why I decided to buy this truck.If you are interested.
woody82 is offline   Reply With Quote
Old 07-06-2014, 10:59 AM   #2
ssxty8
Re: Could it be a posi.?
If only one wheel was in the air, and it was impossible to turn, it's a posi. My 68 Camaro 12 bolt posi reacts the same.
ssxty8 is offline   Reply With Quote
Old 07-06-2014, 11:17 AM   #3
1972RedNeck
1972RedNeck's Avatar
if only one tire is in the air and the tranny is in park (or any gear on a manual) the tire won't turn. If the tranny was in neutral and the tire wouldn't turn, then it is a posi.
1972RedNeck is offline   Reply With Quote
Old 07-06-2014, 08:42 PM   #4
airdale94
airdale94's Avatar
The other side wouldn't turn because the resistance between the tire and the ground was to great.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 07-06-2014, 09:12 PM   #5
sboris
sboris's Avatar
Welcome Woody82 ! Yes stories with pics are always interesting..
(Check out the Iowa section for local happenings)
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
