Old 07-06-2014, 11:10 AM   #1
supercharged
supercharged's Avatar
Rear Tire/Wheel Question
Without altering the stock rear suspension what is the largest and widest tire / wheel non-low-profie combo that can be run on a 1964-1966 stepside short bed?
I am asking about old school 15-16" wheels and tire combos.. something that looks like this ....
Supercharged Scottsman
Scottish by birth, American by law,
Texan by the grace of God.
“To avoid criticism say nothing, do nothing, be nothing.”
― Aristotle
supercharged is offline   Reply With Quote
Old 07-06-2014, 11:40 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Rear Tire/Wheel Question
I run a 295/45/18 which is 11.5 wide and 28 tall
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-06-2014, 01:02 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
afaik, I've got damn-near the most tire you can stick under these things, on a 15" wheel. Any wider, and you've gotta increase diameter slightly, so the wheel clears the shackle on the trailing arms. If you had tubular arms, you can probably sneak another 3/4".
325/50/15 Mt (could go MAYBE 3/8" wider but don't wanna push it) on a 3piece beadlock.
To get that to fit a stock width rear end, you need nearly 8.5" of backspace, which some companies won't/can't do on certain wheels.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-06-2014, 06:00 PM   #4
supercharged
BR3W CITY
That is awesome
Right now I am only running P275/60R15 (10 13/16” wide and 28” diameter)
― Aristotle
