![]() Join Date: Mar 2006
trailing arms u bolts?
Where can you but new trailing arm u bolts for a C10/ thanks Rick
Re: trailing arms u bolts?
Early classic sells them. If not you can check a tractor supply store.
Old Skool Club
![]() Join Date: Jun 2001
My son took my old one to a big truck repair facility, and they bent me a new pair from good stuff...and furnished the washers and nuts. Cost me less than $15.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
I got mine from Classic Parts of America 816-741-8029. They are the correct diameter and length....fit perfect.
thanks guys
Anywhere BUT LMC! When I changed mine I bought the new ones there. Those nuts get torqued between 180 and 250 ft lbs according to the factory assembly manual. LMC sent grade three nuts with half the grip length of the originals. The threads stripped at 130 ft-lbs. Last time I will ever buy from them.
That's what I did and about the same price make them while you wait.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel |
