Old 07-06-2014, 04:42 PM   #1
Procurement_man
Procurement_man's Avatar
clutch delete plug
Wondering how the metal plug installed. Was it on the inside or outside of firewall? Did it just use sheet metal screws? I'm sure someone knows....
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel
Procurement_man is offline   Reply With Quote
Old 07-06-2014, 04:46 PM   #2
davepl
davepl's Avatar
Re: clutch delete plug
I don't even appear to have a hole where a clutch rod -could- come through on my TH400 truck. In that area the firewall is flat but has about 6 pinch welds.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-06-2014, 04:48 PM   #3
davepl
davepl's Avatar
Never mind, I found this photo in my teardown info. But my clutch linkage opening is completely open, only the jute covers it. I assume that's incorrect.
Old 07-06-2014, 05:12 PM   #4
FirstOwner69
FirstOwner69's Avatar
The earlier trucks, through 70 I believe, used gray plastic plugs on the outside of the firewall. I see you found this thread for them http://67-72chevytrucks.com/vboard/s...d.php?t=535199 . GM later (1971?) switched to metal covers with a rubber backing that screwed on from the outside of the firewalls.
Here's a plug installed on my 69.
FirstOwner69 is offline   Reply With Quote
Old 07-06-2014, 07:26 PM   #5
JointTech
JointTech's Avatar
im in the process of welding mine up. there was a metal cover that screws in from the outside with a rubber gasket.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
