Old 07-06-2014, 06:41 PM   #1
omgitsemmanuel
What tire size for 17s
I plan on going with some 17 on my 64 c10 stepside but dont know what tire size to go with. Having trouble finding some trucks on 17 in these years. Any info would help
omgitsemmanuel is offline   Reply With Quote
Old 07-07-2014, 10:04 AM   #2
earl84
Re: What tire size for 17s
Your question is a little vague. Not sure exactly what you are looking to accomplish, so it's hard to answer. Do you want it to look stock, sort of? Are you going to lower it and want them to tuck? Do you want them as wide as possible? In the meantime, here's a link to a site that you can do some comparisons with that I have found helpful: http://www.miata.net/garage/tirecalc.html
earl84 is offline   Reply With Quote
Old 07-07-2014, 10:09 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Tire size and wheel width are directly related.
What size wheels?
Keith
Convert to disc brakes.
Old 07-07-2014, 03:27 PM   #4
LVPhotos
LVPhotos's Avatar
Looking at stock size 235/75/15 I went 235/60/15 and a 275/60 rear. Couldn't find 17s I liked. Went 18x9.5 and 18x8. 295/45/18 which is 28 tall and 11.5 wide Nitto 555s best bet use the the tire calculator on Discount Tire or other sites.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-07-2014, 03:30 PM   #5
LVPhotos
LVPhotos's Avatar
One more.
Old 07-09-2014, 12:27 AM   #6
omgitsemmanuel
Well I was planning on running 17 but I have a 72 12 bolt posi and its wider so I would need a bit of backspacing on a 17. The problem is that on a 8 inch rim I would need 5 inch backspacing to get it right on and finding a cost efficient wheel with that backspacing is pretty hard so Im sort of confused on what to go with now.
Old 07-09-2014, 01:12 AM   #7
66LSx
66LSx's Avatar
Any pictures of the front or the entire package (front and rear?)
I am planning the same boat (18x8 front, 18x9.5 rear.... LOVE what you have going on)
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 07-09-2014, 03:44 AM   #8
Slow Build
Slow Build's Avatar
From a different thread.
Originally Posted by 72bigblockw/air View Post
17"x8" front with a 255/50/17
17"x9.5" rear with 275/50/17
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 07-09-2014, 11:03 AM   #9
LVPhotos
LVPhotos's Avatar
Waiting for PorterBuilt front to come back from powdercoat and brakes from California. Getting closer to having the front in and done but 245/40/18 for front. Had hard time finding 17s in right size gave up and went 18. Still meat on tire and right height and width.
Old 07-09-2014, 04:36 PM   #10
forestb
forestb's Avatar
5/5 drop with 275/55R17 in the rear and 275/50R17 up front
forestb is offline   Reply With Quote
