Old 07-06-2014, 07:40 PM   #1
ericjon262
70 GMC, 1/2 ton to 3/4 ton...
I recently picked up a 70 GMC 3/4 parts truck for my 1/2 ton, I plan to swap all the 3/4 ton suspension over to my 1/2 ton, anyone done this? and build threads or suggestions. the body on the parts truck is total garbage, or at least to the extent that I know I won't be able to fix it with the time I would have available.
Thanks-
Eric
'06 2500 HD 4x4. manual transfer case, crank windows.
'88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project.
My trucks don't leak oil, they mark their territory.
ericjon262 is offline   Reply With Quote
Old 07-06-2014, 07:47 PM   #2
fencepost
fencepost's Avatar
Re: 70 GMC, 1/2 ton to 3/4 ton...
theres a real good 3/4 to 1/2 thread on here might be able reverse engineer it. A body swap would be that big of a deal.
fencepost is offline   Reply With Quote
Old 07-06-2014, 07:56 PM   #3
68350
68350's Avatar
You should keep the 3/4 frame and running gear and do a body swap. 3/4 frames are beefier than 1/2 frames. Require different cab mounts(the rubber ones).
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 07-06-2014, 08:54 PM   #4
ericjon262
I've been considering the body swap more and more, the parts truck has power brakes, which I noticed also have different lines from the manual brakes, another problem I'm facing is the bed on the parts truck is an 8.5' bed (in bad shape) versus my trucks 8' bed. do you know of any good threads that outline how to pull the existing body and swap the new one on? I did a search and it seemed like most threads were long build threads.
Old 07-06-2014, 09:00 PM   #5
sboris
sboris's Avatar
Sounds like you may have acquired a longhorn. Cool.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 07-06-2014, 10:00 PM   #6
ericjon262
does being a longhorn make it desirable?
Old 07-07-2014, 12:37 PM   #7
Shakerattlenroll
There is a lot less of them ;-)
Shakerattlenroll is offline   Reply With Quote
Old 07-07-2014, 04:20 PM   #8
ericjon262
there may be less of them, but that doesn't necessarily equate to desirability...
I think I'm going to swap the 3/4 ton parts to my truck, as I don't have as much time to work on it, and I can do it in phases without keeping the truck off of the road for extended periods of time.
Old 07-07-2014, 09:08 PM   #9
ericjon262
I'm starting to think more and more this would be a better idea. I looked under my truck to confirm the frame differences, and you're right, the 3/4 ton is beefier. it would also prevent numerous headaches that I know would be caused by the brake lines (they have a habit of tormenting me) I see you mention the cab mounts are different, are the cabs themselves the same? anyone have a recommended procedure for the swap? I need to do it fairly quickly as the truck is also my DD. at the moment, I don't plan on doing any restoration work unless absolutely necessary.
Thanks-
Eric
Old 07-07-2014, 09:10 PM   #10
71swb4x4
71swb4x4's Avatar
Cabs and all other sheet metal is the same. Get joesjunk over here, he has done several cab swaps.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-07-2014, 09:26 PM   #11
ericjon262
I sent him a PM, hopefully he'll chime in.
Old 07-07-2014, 09:44 PM   #12
Jake1971
Jake1971's Avatar
Re: 70 GMC, ..
Looks like a possible truck to pick parts from coming up if you decide to go that way after your 1/2 ton to 3/4 ton swap. Let us know
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline   Reply With Quote
Old 07-07-2014, 10:01 PM   #13
ericjon262
Re: 70 GMC, ..
we'll see, I'd like to sell the 1/2 ton when the swap is done because it does run and drive ok.
Old 07-08-2014, 02:13 PM   #14
Joesjunk
Joesjunk's Avatar
I replied to your PM. I must ask though, what are you looking to gain with this? Are you needing a 3/4 ton truck? And you will still have drum brakes if you are wanting to use the 70 3/4 ton stuff. If you are just looking to add power brakes, its super easy to add the power brake booster to your truck. Let me know if I can help.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 07-08-2014, 02:44 PM   #15
ericjon262
This is a very valid question to ask, I bought the truck(1/2 ton) to use as a truck(towing, hauling, ect), and really, I wanted a 3/4 or 1 ton over a 1/2 ton, but the truck was a really good deal. I've recently used my truck(1/2 ton) to tow a U haul trailer with a small car while changing duty stations, and very quickly realized the 1/2 ton was about at it's limits. When I saw the 3/4 ton on base, I jumped at the opportunity.
While power brakes are a nice little upgrade, they are hardly the driving force for why I want to do the swap. I had initially planned to swap 3/4 ton 4x4 gear into my truck anyways, so this route just seemed a bit easier, and a step closer to the finished product that I desire.
heres how I plan to swap the cabs ATM.
  1. disconnect battery
  2. remove front sheet metal (hood fenders grill ect
  3. disconnect and remove a/c and a/c box
  4. disconnect steering column and shift linkage
  5. disconnect and unbolt brake booster
  6. drain the gas tank, remove lines.
  7. remove seat.
  8. disconnect wiring harness.
  9. unbolt the cab.
  10. lift off cab.
  11. start over in reverse.
Am I missing anything?
Thanks-
Eric
Old 07-13-2014, 03:16 PM   #16
ericjon262
I'll be starting work soon, I found this thread and it's been very helpful
http://67-72chevytrucks.com/vboard/s...d.php?t=194094
doesn't say anything about the cab itself, but has lots of info on the front sheetmetal.
Old 07-26-2014, 05:10 PM   #17
ericjon262
Started swapping the cabs, here are the progress pics from the past 2 days.
any other progress is being documented in my build thread, linked below.
http://67-72chevytrucks.com/vboard/s...d.php?t=594908
Old 07-29-2014, 10:54 AM   #18
71veronica
71veronica's Avatar
You'll love the 3/4 ton. They are awesome to tow with. I towed a 79 f 1 fix me with mine didn't even notice it was behind me. 502 big block help
71veronica is offline   Reply With Quote
Old 07-29-2014, 07:12 PM   #19
ericjon262
fuel line decided to spray fuel like a firehose... other one barely dripped...
lifted the 1/2 ton cab off...
rolled the 1/2 ton frame out and the 3/4 ton frame in...
Set the Cab down...
and this was how I left it...
Old 07-31-2014, 09:50 PM   #20
ericjon262
Out with the old rotten core support...
in with the "new" core support.
front sheet metal installed
drove it home...
