Old 07-06-2014, 08:39 PM   #1
davepl
davepl's Avatar
Thermac switch?
I might have the wrong name, as I'm having no luck finding it.
I need the little thermal vacuum switch that goes inside the air cleaner housing and controls the opening of the heat stove flapper valve.
Anyone know what its called and where I can find them? Should be a common service part, you'd think.
Thanks!
Dave
PS: In case anyone ever wonders, I had my Air Cleaner housing powder coated. I was worried that the heat would ruin the return spring and didn't want to take it apart, so risked it. All tests are fine, I've connected vacuum and seen it do its thing and watched it return.
For that matter I had my front coil springs done too, and they're probably more important than the emissions flapper door air cleaner return spring!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-19-2014, 05:51 PM   #2
davepl
davepl's Avatar
Re: Thermac switch?
TTT
Still broken, still need one. Gotta be a million of them in wrecking yards, I just don't have one of those for 50 miles....
Old 07-19-2014, 06:03 PM   #3
davepl
davepl's Avatar
Re: Thermac switch?
BTW, I can't find them at auto parts stores or LMC or Brothers or CI or anywhere. eBay has a few listings, but none that claim to be compatible with my truck. The closest looking one I can find is the ATS22, but they're about $50 on eBay
http://www.ebay.com/itm/Standard-Mot...b1d3f7&vxp=mtr
Old 07-19-2014, 06:06 PM   #4
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: Thermac switch?
Look like this ?
Oldtruckfanatic is offline   Reply With Quote
Old 07-19-2014, 06:10 PM   #5
davepl
davepl's Avatar
Re: Thermac switch?
Yes, please remove it carefully before sending it to me :-) I would probably need the retaining clip as well, I think.
In all seriousness, is it a part you'll part with?
Dave
Old 07-19-2014, 06:17 PM   #6
Oldtruckfanatic
Truck junkie
Re: Thermac switch?
I have the entire assembly Its off of a 71 350. Id rather send you the entire air cleaner housing I really dont want to break the switch lol
Old 07-19-2014, 06:43 PM   #7
davepl
davepl's Avatar
Re: Thermac switch?
Before asking you to ship a huge unit, I did a little more anthropology. In my parts counter book it shows the GM part number as 3979573. Googling that with "interchange" took me to some photos, so picking the ones that looked like it led me to this supposed interchange list:
GM 3979573
#19111948
Standard ATS6
Five bucks on Rock Auto. They don't show it fitting my truck, but they have it under "1978 C10 250cid L6".
http://www.rockauto.com/catalog/more...157&cc=1296413
Old 07-19-2014, 06:55 PM   #8
Oldtruckfanatic
Truck junkie
Re: Thermac switch?
No problem I bet that willl work. Im just afraid to break this one trying to get it out for you. I have no problem parting with it I dont do restorations on my own stuff Just hotrods. This air cleaner has been sitting on the stock engine from that truck in the corner of my shop for a year.
Old 07-19-2014, 06:57 PM   #9
davepl
davepl's Avatar
Re: Thermac switch?
Do you know if that's off a 396 or a 350? I'm pretty sure I'm missing the retaining clip. I had mine powder coated so I stripped it apart, which is how I got into this mess.
Old 07-19-2014, 06:59 PM   #10
Oldtruckfanatic
Truck junkie
Re: Thermac switch?
Its a factory 350 from a 71 camper special. I have a 402 but the air cleaner was long gone when I got it.
Old 07-19-2014, 07:00 PM   #11
Oldtruckfanatic
Truck junkie
Re: Thermac switch?
Let me see if I can remove it. Its not like im going to use it.
Old 07-19-2014, 07:02 PM   #12
davepl
davepl's Avatar
Re: Thermac switch?
I was going to encourage you to try, but didn't want you to break it. Since I can probably find the switch, it's not the end of the world even if it does break. But the clip is... that's the apocalypse right there if I can't get that. Well, I could be exaggerating :-)
Let me know if you can get it out, how much you'd like, and how to send it to you!
Thanks much!
Dave
Old 07-19-2014, 07:03 PM   #13
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Thermac switch?
Here is what the manual calls it. How it works.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-19-2014, 07:05 PM   #14
davepl
davepl's Avatar
Re: Thermac switch?
Yup, I know how they work. I never really know how to test them. I mean you can heat them with a hair dryer, but how do you know if opened/closed at 100F?
You guys in the south could just walk outdoors with it, but not here!
Old 07-19-2014, 07:09 PM   #15
Oldtruckfanatic
Truck junkie
Re: Thermac switch?
Well here it is. Who knows if it works but its not broken nor is the retainer.
Old 07-19-2014, 07:20 PM   #16
Andy4639
Old member
Andy4639's Avatar
Wink Re: Thermac switch?
Here is what the manual says to do to test it.
High tech stuff right here man! Lol...
It would be easy to check it today here it's like 72* and raining.
