Old 07-06-2014, 09:40 PM   #1
Truck Guy99
Iffy A/C just stopped working when stop?
Truck is an 05 Chevy Silverado 1500. About 6 months ago the trucks A/C shut off when you turned the fan speed to 5 but would blow very lightly on 0. All fan speeds between worked fine no matter if you were moving or sitting still. This was never an issue so we just dealt with it. Now when you are sitting still it won't blow at all no matter what you turn the knob to. When you start going down the road, it blows but barely. The air is very cold when it does this. We replaced the A/C fuse and the resistor that I'm told is common to fail and neither changed it or even made a difference. Could it be the climate control or is it something else? I'm in the middle of a Texas summer and need A/C!
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 07-06-2014, 10:42 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Iffy A/C just stopped working when stop?
Was the resistor pigtail melted? There are tsbs and recalls on the pigtail and resistor.
The motor could be the problem. It could be the control head.
Does the truck have automatic climate control? Or just standard controls?
95 S_Trucker is offline   Reply With Quote
Old 07-07-2014, 12:10 AM   #3
Truck Guy99
Resistor pigtail was in great shape. Looked like it may have been replaced before but not sure
I'm assuming standard controls by the looks of it
How do I diagnose if it's the control head or motor?
Old 07-07-2014, 09:24 AM   #4
95 S_Trucker
Those are standard controls.
Check for power and ground at the blower motor connector with a multimeter. unplug the blower. using dc volt setting on a meter, carefully back probe or hold the leads up to the blower motor connector. Then turn the key on and go through all the speeds. The voltage should vary, with 5 being close to full battery voltage. If everything is good, replace the motor.
A quick way to test the motor is turn the key on, turn the speed to 5, then give the motor a wap, with a small hammer, a foot, or a fist. If the motor starts to run, replace it.
Is that a 1500HD? I see a trans temp guage
Old 07-08-2014, 04:49 AM   #5
Truck Guy99
No, that's a pic from google images
Old 07-08-2014, 11:33 AM   #6
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
same thing happened to me...blower motor resistor melted...I ordered one from amazon and replaced it...my part number for my 02 2500HD 8.1 was a dorman 973-004. takes about 15 minutes to replace...now all speeds work and blows fine.
check the image below
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 08-06-2014, 07:20 AM   #7
Truck Guy99
Ok so I got the issue fixed. It was a bad resistor and the control. The control panel wouldn't light up with the rest of the interior and when it did it was usually dim. This told me was shorted out. But now there is melted wiring on the pigtail of the resister on the truck side. Where can I get a replacement? Its the plug that comes from the dash, not the resistor.
Old 08-06-2014, 02:44 PM   #8
Mr-Jack
Mr-Jack's Avatar
junkyard?
Old 08-07-2014, 10:18 AM   #9
truckdude239
truckdude239's Avatar
gm sells them
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
