Old 07-07-2014, 11:46 AM   #1
Iraqvet05
axle ID help
I have a bad rear u-joint on my 01' 2500HD 4WD. Several part sites mention there are two axle manufacturers and the joints for each are not interchangeable. How do I identify the manufacturer of my axle? Is the manufacturers name on a tag or do I ID by the bolt pattern on the diff cover? It’s going to be a Spicer or America (AAM) and I have a 4.10 gear…. that’s about all I know.
Iraqvet05 is offline   Reply With Quote
Old 07-07-2014, 03:18 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: axle ID help
It could be a corporate 14 Bolt, 10.5" ring gear
or a AAM 11.5" Ring gear.
The 14 Bolt will have a removable pinion support, where the 11.5 will not. That is the easiest way to tell them apart.
95 S_Trucker is offline   Reply With Quote
Old 07-08-2014, 09:04 AM   #3
Iraqvet05
Re: axle ID help
After a little more digging, I found I have the corporate 14 bolt (based on the diff cover bolt pattern). Most of the websites I was using state the axle will be a Spicer or AAM but it's not the axle I should have been looking at, it's the driveshaft. I found Spicer stamped into mine near the carrier bearing.
Old 07-08-2014, 10:23 AM   #4
95 S_Trucker
Re: axle ID help
spicer will probably be stamped on the driveshaft whether the truck has a 14 bolt or an AAM. You need to know which rear end you have so you can get the proper sized u-joint.
I highly recommend the spicer life u joint. Will outlast anything out there, including precision and moog.
Old 07-08-2014, 10:38 AM   #5
Iraqvet05
Re: axle ID help
OK, let me go crawl under the truck again and see what I can find on the axle. This driveshaft site says to check the driveshaft and RockAuto and several others says to check the axle....very confusing.
http://www.dennysdriveshaft.com/c629...78_inches.html
Old 07-08-2014, 07:11 PM   #6
clinebarger
Re: axle ID help
If you have a Allison or ZF S6-650 trans.....You have a 11.5" AAM diff.
If you have a 4L80E or a NV4500.....You have a 10.5" 14-bolt (Corporate).
As for identifying U-joint by the axle doesn't sound right to me, I have a 11.5" AAM in my truck, But uses standard Spicer U-joints Not the odd ball AAM joints.
Measure the joints to be sure!
clinebarger is offline   Reply With Quote
