Old 07-07-2014, 12:45 PM   #1
Shakerattlenroll
Front end swap question
Anyone ever pull the whole front end off the frame of a 73-80 half ton and bolt it rite onto a 67-72 ?
Shakerattlenroll is offline   Reply With Quote
Old 07-07-2014, 04:49 PM   #2
Shakerattlenroll
Re: Front end swap question
I know the stearing box swaps ..
if you use the pitman arm from 67-72.
And I know the whole assembly will drop in a 63.
Reason I ask is because I was thinking discs
Old 07-07-2014, 04:56 PM   #3
motorcritter
motorcritter's Avatar
Check the FAQs for suspension/brake stuff. All your dreams can come true!
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 07-07-2014, 05:01 PM   #4
Shakerattlenroll
Sweet :-)
Kinda new here , never thought about that
Old 07-07-2014, 08:41 PM   #5
hugger6933
I have not done it personally but know of it being done hundreds of times. To use the 73 -87 cross member one bolt hole has to be drilled but it will be evident when the others are lined up. Jim
hugger6933 is offline   Reply With Quote
