Old 07-07-2014, 03:06 PM   #1
Tuff 1986
Tuff 1986's Avatar
Cargo lamp help..
My cargo lamp does not work.. I have the right bulb in and I'm getting power to the cargo lamp switch.. When switch is on off only one wire is hot and when I switch it to on both wires are hot.. When switch is on I stick my tester behind the bulb switch and it's a hit and miss sorta thing.. It will light up so time and sometimes it won't.. Could it be a ground somewhere by the bulb pig tail?
Will I ever finish my 1986 stepper..
Tuff 1986 is offline   Reply With Quote
Old 07-07-2014, 03:56 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Cargo lamp help..
Possibly a bad socket for the lamp itself. I've never looked at the wiring diagram for a cargo lamp, but if it's anything like the dome lamp, it would be hot all the time and the ground is switched. If that's the case, look elsewhere. It could be a ground problem. If it's a conventional switch that switches the 12v side of the circuit, then you're on the right track. You have power on both sides of the switch when activated, so the switch works. If you're only intermittently getting 12v at the socket itself, then that sounds like your problem if you have a constant 12v at the wire/s going to it.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 07-07-2014, 09:57 PM   #3
Oldriginal86
Remove the bulb then check for power. One side will have power, other will be grounded through the switch.
Oldriginal86 is offline   Reply With Quote
Old 07-09-2014, 04:13 PM   #4
Tuff 1986
Tuff 1986's Avatar
Thanks guys for your help..
Old 07-10-2014, 12:47 AM   #5
bilfman
bilfman's Avatar
I had the same issue with mine it was a bad ground . Rather then trace that all the way back I just made a lead and grounded it by the light it self.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 07-13-2014, 01:36 PM   #6
Tuff 1986
Tuff 1986's Avatar
Can u tell me where exactly did you put the lead at? I want to see if this will solve my problem..
Old 07-13-2014, 03:02 PM   #7
chengny
chengny's Avatar
The cargo light is back to back with the dome light. Pull the dome light base and ground the white lead from the cargo light to one of the dome light mounting screws.
chengny is offline   Reply With Quote
Old 07-13-2014, 03:27 PM   #8
Tuff 1986
Tuff 1986's Avatar
Thing is I don't have a dome light.. I have a light under the glovebox and ashtray area.. Behind my bench seat is a white and a orange wire can I do anything with those wires?
Old 07-13-2014, 04:15 PM   #9
Just call me Sean
Just call me Sean's Avatar
Those are the dome light wires.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 07-13-2014, 05:17 PM   #10
Tuff 1986
Tuff 1986's Avatar
Thanks guys!! I got it to work.. I ended up soldering one end of a wire to the white wire at the base of the bulb socket and wraped the other end to the mounting bolt.. Now it works fine..
