Old 07-07-2014, 04:17 PM   #1
lgvl
lgvl's Avatar
Shake a leg...or truck
So i was coming home on the highway last week doing 65mph and noticed that there was a great amount of vibration in the truck, '82 C30 dually, bad enough that the dash was squeaking because it was moving back and forth so quickly. But i didn't have any vibration in the steering wheel. It only happened above 60mph, however i have now noticed vibration at 45mph as well. So long story short i figured it was the carrier bearing and after some inspection of the u-joints decided to replace both the carrier bearing and all three u-joints. This was done and after reinstallation i still have the exact same problem. I'm trying to avoid having to take the drive shafts in for balancing and i seem to remember not having this problem until i hit a curb with the back passenger tire a couple weeks ago. Any suggestions? It just seems odd to me that drive shaft would all of a sudden go unbalanced. Could hitting the curb have unbalanced the drive shaft? I don't see how. Thanks!
'82 C30 3+3 Dually 454
lgvl is offline   Reply With Quote
Old 07-07-2014, 05:01 PM   #2
J Knight
J Knight's Avatar
Re: Shake a leg...or truck
Sounds to me like you could have slipped belts in the tire you curb checked.
Lift the tire you hit and spin it to see if you have a knot in that tire.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-07-2014, 05:02 PM   #3
wjjeeper
wjjeeper's Avatar
Check your rims for lost weights or mud packed in places.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 07-07-2014, 09:50 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
or a bubble on the inside of the tires
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-07-2014, 09:54 PM   #5
mrolds88
Also check the pinion bearing. Had a Suburban loosen the pinion nut once. WOW??
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-08-2014, 02:22 AM   #6
andrewmp6
It could be you knocked a weight off the wheel or bent the wheel,Or if you hit it hard enough could have bent a axle shaft.
andrewmp6 is offline   Reply With Quote
Old 08-31-2014, 02:37 PM   #7
lgvl
lgvl's Avatar
Sorry for not commenting earlier, i work at sea and had to go to work a few days after i posted this. As you can imagine i usually have more important things to do, like spending time with family, than working on my truck before leaving so didn't get much time to trouble shoot until now. Anyway, I removed both of the rear driver side tires and both have nice big bulges in them under the tread at one point. I'm guessing this is a result of the plies coming apart. So I will be going to get two new tires. My plan is to swap the two old front tires to the back with the other two good old tires and put the new ones on the front. How does that sound to everyone? I know matching tires on the rear of a dually is important. Thanks for the help everyone!
Old 09-01-2014, 12:18 AM   #8
Your41Plague12
Your41Plague12's Avatar
That's exactly what I would do. Sounds like you found your problem, let us know how it works.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
