07-07-2014, 04:28 PM | #1 |
2000 GMC running hot?
My dad has a 2000 GMC 1/2 ton ext cab P/U w the small V8(size escapes me right now). Last summer he noticed when he towed it would run a little hot. He was convinced it was the transmission bc the truck now has 150,000 + miles on so he had it rebuilt. That did not fix this problem so he went ahead and replaced the water pump but this did nothing either. The truck is not burning oil, using any water ect. Runs perfect but you can put an empty 20 ft HD low boy behind it and it will climb to about 235 or so. Never overheats. Do these lil motors just run hot under a load?
Preserving American History one truck at a time. |
07-07-2014, 10:21 PM | #2 |
Re: 2000 GMC running hot?
Radiator half clogged either internal or external (Between the condenser & radiator with debris), Seen it many times. If you drove it up to 90mph empty you would get the same result.
07-08-2014, 10:20 AM | #3 |
ok Thanks, I will look into that.
07-08-2014, 11:27 AM | #4 |
Beer Drink'n Knuckle Dragger
If that doesn't work, try a flush and inspect the fluids...also it's the 4.8L v8 is Chevy's small vortec V8
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe |
07-08-2014, 02:30 PM | #5 |
That's the motor. well dad said he replaced the radiator at the end of last summer when he changed the water pump. So he's going to look for any external blockage. I suppose it could be clogged ports in the heads or engine as well or the temp sending unit isn't accurate???
08-05-2014, 10:29 PM | #6 |
87 Wanna Be K30
If you haven't figured it out yet......
Maybe check into the fan clutch. Might not me engaging when the temperature increases. Sometimes they will spin with very little resistance when the engine is off. The fan being incapable of pulling a higher volume of air as temp increases would cause your symptoms. Just a thought
Was: 1987 V10 Silverado TBI 350/700R4/208 with 3.42 gears Is: A wanna be K30 330hp 350/465/205/D60/14FF with 3.73 hydroboost, 4 Core radiator, electric fans, Centerforce Duel Friction, Locker, 6inch Soft ride lift, etc.... |
08-06-2014, 10:12 AM | #7 |
Yea I appreciate but that was one of the first things we looked at.
08-17-2014, 09:48 AM | #8 |
I would try tunning of the ECM. Have them Change some stuff around like transmission oil pressure and shift points and fueling. I would suggest it is the torque converter. Was it replaced with transmission? Hope this helps.
My smart phone makes me look dumb when I types. |
08-17-2014, 03:39 PM | #9 |
my buddy's s10 does this with the 4.3 l v6 towin an empty 6x12 trailer we've havent been able to figure ti out We put a new denso/ ac/deco raditor in it new water pump New gm thermostat, new gm radiator cap, end up replaceing the motor due to blown head gasket haven;t had an issues since
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
