07-07-2014, 07:29 PM | #1 |
My Rocker Bondo/Bedliner Job
Here is a project ive been working on this week. I had some pretty big holes in my rockers from rust and some bad bubbling behind the doors, I was planning on having it professionally done but I just dont have the money so heres what I did.
-removed all paint and rust in the affected area with a wire brush cup (i got an attatchment for a power drill) -hit the remaining rust with rust resolver/primer -Used bondo glass and fiberglass cloth to cover holes and rust -Sanded bondo then painted the lower side of truck with herculiner bed liner -Painted wheel wells and underside with rusoleum rubberized undercoating And heres what it looks like as it sits, with one side finished. Best of all, supplies didnt even run me 200$. Id say thats a tad cheaper than taking it into a body shop. Figured this might give some of you some ideas about tackling your own rockers. I plan to finish up the other side, and paint my grille insert a flat black to really make it look clean on a budget. |
07-07-2014, 08:26 PM | #2 |
Re: My Rocker Bondo/Bedliner Job
nice but hate to burst you bubble you can buy a full rocker for less then a can of bondo you could have stripped your old rocker right out and used epoxy to glue a new one in dont worry ive done it your way a million times before i found out how cheap and easy a rocker is to do infact my truck i have now the po who had it before spent more money on metal tape spray foam and bondo to make the rocker on my truck look new then spent i don't know how much on paint when he could spend $26 retail for a new rocker got to say looks really good though
07-07-2014, 08:33 PM | #3 |
google this site it is a canadian sit but down in the states is where most the parts for these truck come from but you would be surprised how cheap body parts are
https://ecat.crosscanadaparts.com/base/welcome.php |
07-07-2014, 10:38 PM | #4 |
Using epoxy to attach the rocker? Does it hold up well? What kind of epoxy? I suppose it might make it easier to line the rocker panel up and no worries about heat warpage.
07-07-2014, 10:41 PM | #5 | |
07-07-2014, 11:01 PM | #6 | |
07-07-2014, 11:04 PM | #7 | |
i think it is made by devcon its a automotive epoxy |
07-07-2014, 11:05 PM | #8 |
there is a special primer used with it too
