Old 07-07-2014, 08:43 PM   #1
davepl
davepl's Avatar
Nutserts
Not really a good for for this, but I'm wondering if someone can tell me the difference between rivet nuts and nutserts.
It doesn't appear to be just a brand thing, from what I can find.
I saw them used on tv and the install tool was huge like a bolt cutter. But the ones on amazon are more like hand rivet tools.
I'd like to get something that will set nuts where I have no access to the backside. But what kind and what tool? I'd like metal, not poly, if it's stronger.
Thanks,
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-07-2014, 09:04 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Nutserts
http://www.67-72chevytrucks.com/vboa...d.php?t=448143
Old 07-07-2014, 09:22 PM   #3
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Nutserts
I work in the stainless steel business and we use nutserts daily, i don't really see a difference in what was posted above. We do use air powered tools to install them though. I hate the metric ones, and i also am a huge anti stainless hardware person too, i hate stainless bolts etc.
but, they are a great tool to use when you can't get to the back of something or really anywhere for that matter for a clean easy to disassemble part.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-07-2014, 09:31 PM   #4
magicoolbus
magicoolbus's Avatar
Re: Nutserts
I think they are two different animals entirely. Rivnut puts threads in a hole where none existed before. A nutsert is a repair item. Search keensert. It is a high end helicoil type repair.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 07-07-2014, 10:23 PM   #5
69chevytrucker
69chevytrucker's Avatar
Re: Nutserts
correct also is used in furniture threaded on the outside put in with allen key and has threads on inside
69chevytrucker is offline   Reply With Quote
Old 07-07-2014, 10:28 PM   #6
69chevytrucker
Re: Nutserts
some different kinds
Old 07-07-2014, 11:45 PM   #7
88Ironduke
Re: Nutserts
I used nutsert on body panels and ground effects for a project car a while back. I get the terminology screwed up threadsert vs nutsert...They were around 7/16" outer diameter and used 1/4" stainless bolts. It used a tool that looked like a really heavy duty rivet gun with a long stem that screwed in to the nut set.
Screw down the nutsert on the stem, insert into the required location and squuueeezzze really frigging hard. They tighten up similar to a rivet but you're left with a threaded insert that can withstand much more force applied to it. It worked flawlessly on body panels that allow you to remove the panels for paint repair at will. The GM body rivets were around 4 bucks per rivet and very permanent. Add in you still needed a special tool for those. Look up Marson 39214 Thread-Sert on Amazon. That's what I used.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 07-08-2014, 03:17 AM   #8
66pnl
66pnl's Avatar
Re: Nutserts
X2 on the marson. Works great. Gotta have a helluva grip to squeeze the tool tho.
66pnl is offline   Reply With Quote
