seam sealers?
What is a good self-leveling sealer that I can use in the drip rail and between other body panels
![]() Join Date: Jul 2010
Re: seam sealers?
Evercoat maxim 100824.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
Re: seam sealers?
I always see shops using 3m so its what comes to mind. I have no idea of quality but its high end shops using it
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
Re: seam sealers?
I used the 3m and worked well..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
Re: seam sealers?
Re: seam sealers?
Here's a link to a thread from last year where this was hashed out.
http://67-72chevytrucks.com/vboard/s...d.php?t=564819
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
Re: seam sealers?
I couldn't get that link to work^
I used the tube style
Re: seam sealers?
Why is that link not working?
Re: seam sealers?
My Camara resto expert buddy showed me a cool tip on my last car
Put the tube in sink of hot water first Flows like peanut butter |
Re: seam sealers?
me neither and I've had it bookmarked for when I do mine, wonder if it's because mister-b got suspended? hopefully the higher power's can fix it, it was a good thread on the subject
1969 Chevy C10 2wd stepside longbox |
Re: seam sealers?
Re: seam sealers?
#13 |
Re: seam sealers?
I am sure all you guys know this but I can't help myself, when using the seam sealer keeping your fingers wet wit water or best case lacquer thinner to move the seam sealer along. It makes for the perfect tooling marks that way and you can do with it what you wish as long as you keep your fingers wet. Well don't complain you get what you pay for
#14 |
Re: seam sealers?
Has anyone painted a truck without sealing the drip rail? Seems like several coats of paint and clear would make it water tight? I like the look of it now that I have all the old gunk cleared out.
1967 C10 SWB Fleetside Duramax/Allison 1966 Chevelle Malibu, EFI BBC, pro touring starter kit |
#15 |
Re: seam sealers?
I used two different 3M products. Turned out great
![]() For the top (self-leveling 08307) ![]() For down the sides (heavy bodied 08308) and all other areas we sealed. More pictures can be seen in my build thread (link in sig) starting around page 20 or so. ![]()
project: "my happy mess" |
#16 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Re: seam sealers?
Joel. e be sure and wear a raincoat while driving your truck if they are predicting rain and don't seal the doors real good as the water will need to get out. GM was not into doing a lot of things to these trucks that was not needed..
