07-07-2014, 10:13 PM | #1 |
Looking for help ls air conditioner question
Just about to take the plunge on a ls swap. I'm gathering info before I start. Will the air conditioner compressor fit in between frame rails using factory brackets
07-08-2014, 10:00 AM | #2 | |
Re: Looking for help ls air conditioner question
I've used both setup in my 68 S/C build and my 69 Suburban build. Lots of photos there.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-08-2014, 10:21 AM | #3 |
I have mine set up using short adapter plates and the engine stands in the six cylinder position. This gives enough room to use a truck A/C compressor and bracket, but routing the lines around the frame rail will be a tight squeeze. I'm currently running without A/C as there are some other things I need to install.
Also, I had to cut the tops off the engine stands and weld them in upside-down to get enough room to clear the exhaust (using a set of 2010 Camaro manifolds). If I did it over again, I'd probably put the engine stands in the stock location and use a high mount A/C compressor.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
07-08-2014, 02:03 PM | #4 |
Can you use the stock brackets and add the high compressor
07-09-2014, 10:39 AM | #5 |
Yeah... I'd do exactly that if I were doing another swap like that. You just need a set of adapter plates to bolt the factory mounts onto the LS.
07-11-2014, 03:10 AM | #6 |
Where do you find the brackets to change to a high mount compressor
07-11-2014, 05:16 AM | #7 |
Kwik Performance makes one http://www.kwikperf.com/lsx_ac.html
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-11-2014, 08:43 AM | #8 |
Holley makes a nice high mount bracket also.
07-14-2014, 08:48 PM | #9 |
Old member
LS brackets also make one. They are who I used.
