Old 07-07-2014, 10:37 PM   #1
47AD
SBC with front mounts with IFS?
Here's a dumb question. On the '47 - '53 AD can a small block Chevy with front motor mounts be used if you're installing a typical IFS crossmember with rack and pinion steering? I had seen a post where a Task Force truck installation had to switch to engine side mounts because the steering rack interfered with the original front mounts.
Dan
47AD is offline   Reply With Quote
Old 07-08-2014, 09:31 AM   #2
Scottshotrods
Re: SBC with front mounts with IFS?
Dan
The front mounts will interfere with the rack and pinion.The side mounts are the way to go.If we can help you out let us know?
Justin
Scottshotrods is offline   Reply With Quote
