Steering shaft shortening ?
I"m at the point where I need to shorten mt steering shaft. I have the captain's bracket on and the box installed. The shaft has already been shortened by the PO but the box was installed wrong so the shaft needs to be shorter. I didn't losen the column before installing the bracket and didn't mark anything. I just pushed the shaft up in the column to get to the bracket and box. It looks like the shaft is about an inch too long right now and I think I have about two more inches to play with by ajusting the column. I'm thinking about pulling the column and cutting it down about 2 inches and welding on the new adapter I will get from captainfab. I don't have a welder so pulling the column was always the plan anyway so I can take it somewhere to get it welded. Does 2 inches sound about right? I don't want to cut too much but if I do a sleeve will fix it. I don't want to leave it too long and have to cut it again.
66 shorty
