07-08-2014, 05:45 AM | #1 |
Steering Wheel hard to turn at low speed
Hey guys. I've been searching for a while can't seem to find a good answer. My steering wheel is hard to turn at low speeds even feels like it's locking up sometimes on my 2002 Silverado 2500 hd 8.1L. This makes it extremely difficult to turn in parking lots or backing up a trailer. I wondered if it was my power steering pump, but it doesn't seem to be making any unusual noise and my brakes seem to work good (hydro boost). Could it be the intermediate shaft? Or something else. Just over 102K on the odometer. Any suggestions?
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
07-08-2014, 03:52 PM | #2 |
Beer Drink'n Knuckle Dragger
Re: Steering Wheel hard to turn at low speed
check the fittings around the pump for leaks and check the hoses for seapage. might be a small air leak...or something as small as not enough fluid or the cap not on all the way.
mine won't turn full lock unless i'm in gear...gotta remember that it's a heavy motor, and that Allison weighs about 1000 lbs. gonna have to be gentle while turning. I got used to being gentle because of my M/T's
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe |
07-08-2014, 03:58 PM | #3 |
Pump turning constantly, no belt slippage, worn steering parts (like ball joints), alignment, tires well inflated? Just thinking.
07-08-2014, 07:34 PM | #4 |
laying low
You can probably give it just a little bit of throttle and it turns just fine right? I have 2 trucks that do this sometimes.
It could be the pump. Or it could be the steering sensor. Just to eliminate any parts of the steering linkage being the cause. Jack the front up and place on jack stands. With the engine off turn the steering wheel from lock to lock and feel for any hard spots. Also do a visual of all the front end parts noting wear items like tierod ends and pitman arm, ball joints, etc. Grab the tire and try wiggling side to side and up and down to insure everything is normal there.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-09-2014, 04:53 AM | #5 |
I think my alignment is off. Looks off just by looking. Plan to get wheels and tires next month so I'll wait until then. Won't be driving too much. I appreciate the input. Everything seems fine on the pump. Fluid level, belts, hoses. I was just curious if anyone had that same problem and the steering shaft had anything to do with it.
07-19-2014, 03:05 PM | #6 |
I had a steering issue in my 00 Silverado. I pulled the ABS fuse and problem went away. I never searched any further for the problem. ABS light is on and stays on. Just a little info. maybe it helps.
Panelman55
In God We trust!!! |
