Old 08-05-2003, 03:46 PM   #1
brad20653
Trans pick help
Whats the easiest trans to put in my 68 with a big block without alot of stuff to do that has OD but wont affect performance?? Puting 3.73 in rear and want to cruz on highway at times .
Soon to have 68 SWB 350 with Turbo350
brad20653 is offline   Reply With Quote
Old 08-05-2003, 03:49 PM   #2
miket
miket's Avatar
You say your truck is tubbed.....rear tire size will play a part...What size tire? My first option would be T350 given your requirements...but if you want an overdrive 200R4/700R4...but how much "big block" do you have?
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 08-05-2003, 03:54 PM   #3
brad20653
454 550hp
Old 08-05-2003, 03:55 PM   #4
brad20653
6 lug 16 "
Old 08-05-2003, 04:09 PM   #5
72c10step
WHYBYNU when old will do?
72c10step's Avatar
I plan to have a 600-700 HP motor in mine when I get finished (in say 5 years, maybe more). If I can find a manual gearbox with overdrive, like a built T-56, I'll Take it, but otherwise the trans I'll probably get is HERE . It's a 4L80E with full manual shifts, needs no computer. It's a little pricey at about $2800, but it can handle over 800 HP, so to me it would be worth it.
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 08-05-2003, 04:19 PM   #6
crazy longhorn
Fabricate till you "puke"
Brad, if you are looking to go auto trans, I would go 400 turbo with a Gear vendors on the back. This route will be a little more pricey than the 700r4 or the 2004r.......but not near as "finnicky". IMO, you wont notice the extra power it take to run the 400 t when you have a BB infront of it, & a good stock build on a 400 with shift kit will take plenty of guff Personally, i like driving a stick, so i went Richmond ROD. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
