Old 07-08-2014, 02:24 PM   #1
73737373
Inner Fender Bolt Treatment
Bolts are all rust free and clean after soaking in vinegar for a couple of days. What do I do now to keep them from rusting? Don't really want to paint them.
73737373 is offline   Reply With Quote
Old 07-08-2014, 02:45 PM   #2
71K20chevy
71K20chevy's Avatar
Re: Inner Fender Bolt Treatment
Black oxide is what the factory used, you can get the kit from Eastwood I believe.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 07-08-2014, 02:46 PM   #3
73737373
Andy,
Thanks.
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
Old 07-08-2014, 03:11 PM   #4
FirstOwner69
FirstOwner69's Avatar
What I did (did not use vinegar):
1) Thoroughly wire brushed, cleaned threads with a die and degreased.
2) Soaked in hot phosphoric acid (couple hours or as needed...some overnight) to remove rust after wire brushing. This turned them black/black phosphated them.
3) Rinsed with water, wiped dry and let completely air dry.
4) Brushed lightly, wiped with paper towel then soaked in 70% rubbing alcohol, wiped and let completely air dry.
5) Applied liquid gun blue and let soak for 5-10 minutes while keeping them wet with gun blue.
6) Rinsed and dried.
7) Tossed in heated trans fluid for a few minutes then wiped off excess.
The phosphoric acid used was Klean Strip Prep and Etch from Home Depot. About $16/gallon.
The heated phosphoric acid definitely started the removal/phosphating process faster than cold. Heating the trans fluid probably didn't matter.
I can't say how it will hold up for the long term, but they've held up well since last summer through a very cold winter, lots of humidity and multiple condensation cycles.
FirstOwner69 is offline   Reply With Quote
Old 07-08-2014, 04:44 PM   #5
flykelley
Fluid film, love it use it all the time. Leaves a nice thick oily coat. It works great on battery post.
Mike
flykelley is offline   Reply With Quote
