Old 07-08-2014, 03:16 PM   #1
East Tex
Plumbing my LS
I'm running my fuel lines and was curious if this 10 micron filter was a good choice. I'm running an in tank pump with a return line.
http://www.summitracing.com/parts/hly-162-550
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068
East Tex is offline   Reply With Quote
Old 07-08-2014, 03:47 PM   #2
littlevictories
Re: Plumbing my LS
I went with a gf652. It's a delco part and it's used on a ton of cars, so it's available pretty much everywhere
littlevictories is offline   Reply With Quote
Old 07-08-2014, 09:52 PM   #3
Hart_Rod
Hart_Rod's Avatar
Re: Plumbing my LS
10 micron is good for the post pump filter.
Hart_Rod is offline   Reply With Quote
Old 07-12-2014, 09:53 AM   #4
East Tex
Re: Plumbing my LS
Thanks Hart Rod. I'm gonna tackle this plumbing today.
Old 07-12-2014, 10:03 AM   #5
East Tex
Re: Plumbing my LS
Old 07-13-2014, 02:37 AM   #6
siggyfreud
siggyfreud's Avatar
Re: Plumbing my LS
Looks good. If you don't have the AN line cutting tool I recommend using electrical tape and a cutoff wheel. I tried the hammer/sharp chisel method and didn't find that it worked that well at all. I just put a cutoff wheel on my 4.5" grinder and it worked awesome. I ran all AN flex line so had to do a lot of cutting.
siggyfreud is offline   Reply With Quote
Old 07-13-2014, 08:16 AM   #7
truckdude239
truckdude239's Avatar
Re: Plumbing my LS
I used duck tape and a cut off wheel doing mine
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-15-2014, 08:12 AM   #8
East Tex
Re: Plumbing my LS
The tape/cut off wheel method, is what I did and it works great. Thanks
Old 07-15-2014, 09:11 AM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Plumbing my LS
Electrical tape and a band saw works well, too.
Make sure no matter how you cut it, you flush the lines out before you run the truck. You don't want all those bits of hose clogging up your injectors or your fuel filter.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-17-2014, 08:31 AM   #10
East Tex
Re: Plumbing my LS
Yes, I am flushing out the lines for sure.
